[GeoNetwork-users] disable lucene index Rebuild on startup
I am using the latest geonetwork and hosting more than 100, 000 records.
But now I have a problem: the geonetwork rebuilds index when I restart the
application. It lasts hours to rebuild the index and the number of records
users can get change when the geonetwork rebuilds index. It means users
can't get exact search results during geontwork rebuilds index. I wonder if
there a way to disable lucene index rebuild on geonetwork startup.
Thanks and best regards,
Kai Liu
hi Kai,
are you sure that the whole index is rebuilt ? What should happen is that
GeoNetwork compares the changeDate column for each metadata in the DB, to
the last change date recorded in the Lucene index. Only md that are
modified after they were last indexed are actually re-indexed.
You can check what happens if you set DEBUG log level for category
geonetwork.datamanager, in WEB-INF/log4j.cfg.
Kind regards
Heikki Doeleman
On Thu, Jun 6, 2013 at 8:33 PM, Kai Liu <kliu.gis@anonymised.com> wrote:
Kai Liu
How ServiceNow helps IT people transform IT departments:
1. A cloud service to automate IT design, transition and operations
2. Dashboards that offer high-level views of enterprise services
3. A single system of record for all IT processes
http://p.sf.net/sfu/servicenow-d2d-j
GeoNetwork-users mailing list
Hi Heikki,
I am sure that the index was rebuilt. When I sent Getrecords to the
geonetwork, it shows
<ows:ExceptionReport version="1.0.0" xsi:schemaLocation="
http://www.opengis.net/ows
http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd&quot;&gt;&lt;ows:Exception
exceptionCode="NoApplicableCode"><ows:ExceptionText>java.lang.RuntimeException:
Catalog is indexing records, retry
later.</ows:ExceptionText></ows:Exception></ows:ExceptionReport>
If I search records in the interface, the number is increasing: 25, 60,
213......... , and the files in webapps/geonetw
ork/WEB-INF/data/index/index/eng are new files, their size are increasing
too...
I have another problem, when I havested a catalogue which has more than
10000 records. It showes 10000 recordes has been added, but only about 5600
records was indexed and can be searched. I wonder if lucene has a limit to
build index in current version.
By the way, there is not category geonetwork.datamanager, in
WEB-INF/log4j.cfg.
Kai Liu
On Jun 6, 2013, at 19:18, heikki <tropicano@anonymised.com> wrote:
hi Kai,
Kind regards
Heikki Doeleman
Kai Liu
yes, the category is missing, but you can just add it, then it should work.
Lucene does not have some limit to the index (and neither does GeoNetwork
constrain this somehow).
When you re-start GeoNetwork, are you sure that nothing happened to the
database, so all records are still there, and without updates ? And are you
sure that the Lucene index is preserved correctly between stopping and
restarting ?
About the second problem, of retrieving more metadata in harvesting than
ends up being searcheable, this might be caused e.g. when returned metadata
is so malformed that GeoNetwork can't make sense of it; or if there is a
character encoding problem, I believe; this kind of thing.
Maybe try setting DEBUG log level for everything, and then see if you can
find out what's happening ?
On Fri, Jun 7, 2013 at 3:18 PM, Kai Liu <kliu.gis@anonymised.com> wrote:
Hi Heikki,
too...
WEB-INF/log4j.cfg.
Kai Liu
hi Kai,
Kind regards
Heikki Doeleman
if
Kai Liu
Hi Heikki and developers,
I changed some codes and it caused the index rebuilding. I checked out a
latest version and re-run the harvest without my modification. Now it works
fine.
Kai Liu
restarting ?
Hi Heikki,
too...
WEB-INF/log4j.cfg.
Kai Liu
hi Kai,
Kind regards
Heikki Doeleman
the
records
if
Kai Liu
