we are in the process of customizing a geonetwork site (2.4RC2 with java
1.6.0_13), so I've tried to deactivate the xsl caching so we dont have to
stop/start the server to each xsl modification.
So I've edited the javax.xml.transform.TransformerFactory file in the
META-INF/services directory and changed the value to
org.apache.xalan.processor.TransformerFactoryImpl.
But then I have a NullPointerException with the following log, any idea?:
Regards
Yves
INFO jeeves.service - -> transforming with stylesheet :
/home/yves/Logiciels/geonetwork2.4/web/geonetwork/xsl/main-page.xsl
WARNING: transformerfactory doesnt like saxon attributes!
ID système inconnu; Ligne #22; Colonne #71; Impossible de trouver la
fonction : tokenize
ID système inconnu; Ligne #22; Colonne #71; jeton de fonction introuvable.
(Emplacement inconnu de l'erreur)java.lang.NullPointerException
396763 [8897128@anonymised.com] ERROR jeeves.service - -> exception during
transformation for : main.home
396764 [8897128@anonymised.com] ERROR jeeves.service - -> (C) stylesheet :
396764 [8897128@anonymised.com] ERROR jeeves.service - -> (C) message : null
396764 [8897128@anonymised.com] ERROR jeeves.service - -> (C) exception :
396764 [8897128@anonymised.com] DEBUG jeeves.service - Raised exception while
executing service
<error id="error">
<message />
<class>NullPointerException</class>
<stack>
<at class="jeeves.utils.Xml" file="Xml.java" line="243"
method="transform" />
<at class="jeeves.utils.Xml" file="Xml.java" line="204"
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="678" method="dispatchOutput" />
file="ServiceManager.java" line="383" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="621" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="174" method="execute" />
file="JeevesServlet.java" line="89" method="doGet" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="707" method="service" />
line="820" method="service" />
<at class="org.mortbay.jetty.servlet.ServletHolder"
file="ServletHolder.java" line="502" method="handle" />
</stack>
<request>
<language>en</language>
<service>main.home</service>
</request>
<response />
</error>
