Hallo,
knows some a way to disable caching of xsl documents?
It's a pity to restart the system for every small change in an included xsl
file.
I added several own schemas to the system and so I have several included
stylesheets to serve the different schemas. For testing it's very
Knows someone a way to avoid restarting? (Firefox browser cache is set to 0,
clear cache without system restart had no effect)
Hans
View this message in context: http://n2.nabble.com/Disable-XSL-caching-tp3596354p3596354.html
Hi Hans,
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk/web/geonetwork/WEB-INF/classes/META-INF/services/README
HTH,
Mathieu
On Mon, Sep 7, 2009 at 11:41 AM, hramthun <hans.ramthun@anonymised.com> wrote:
Hallo,
file.
0,
Hans
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus
on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-users mailing list
Hallo Mathieu,
Thanks for you advice but this doesn't work for included xsl sylesheets.
README content is:
When caching is on, only the main XSL stylesheet
last update date is checked and not all included XSL. If you update
an included stylesheet, cache is still used.
When I edit or show an added schema record the appropriate stylesheet is
included in a main stylesheet (metadata-utils.xsl). There is no effect on
caching with the change of the class as reported in the README file.
Sorry, but this doesn't work for my purpose.
Are there other ideas?
Hans
Mathieu Coudert-3 wrote:
Hi Hans,
HTH,
Mathieu
Hallo,
xsl
file.
0,
Hans
30-Day
focus
on
30-Day
on
View this message in context: http://n2.nabble.com/Disable-XSL-caching-tp3596354p3596620.html
