Hello,
I would like to disable and hide elements in Metadata Edit form. For example
I want the Title to be disabled and Other Citation details to be hidden in
the Identification Info section
What changes should I make for the above? Any help on this regard is highly
appreciated.
Thanks in advance.
Regards
Kumaran
Hi Kumaran,
If you go into the template you want to edit, you'll be on the
"Default view" (says so in the left column). If you go into "XML view"
(bottom of the column), you'll get the XML up. It's then just a matter of
removing the bits you want. I.e.:
<gmd:title>
<gco:CharacterString>This
is the title of the </gco:CharacterString>
</gmd:title>
would delete the title. But you probably don't want to actually delete the
title (I suspect GeoNetwork won't like that) - you can do that for the
"Other Citation details" you want hidden though. Not sure how to
effectively "disable" the title I'm afraid.
Hope that at least gives you a starting point.
Jonathan Moules
<kumaran.narayanaswamy@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>,
<geonetwork-devel@lists.sourceforge.net>
Date: 11/04/2011 17:56
Subject: [GeoNetwork-users] Disabling and Hiding Elements -
Metadata Edit Form
Hello,
example
highly
appreciated.
Thanks in advance.
Regards
Kumaran
Xperia(TM) PLAY
It's a major breakthrough. An authentic gaming
smartphone on the nation's most reliable network.
And it wants your games.
http://p.sf.net/sfu/verizon-sfdev
GeoNetwork-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
