[GeoNetwork-users] Displaying longvarchar type from McKoi db
Hi GN list,
Does anyone know how I display 'longvarchar' types with a database
client. I am using the Druid 3.9 client with a a McKoi db and any field
which is of type 'longvarchar' (such as the 'values' column in the 'settings' table)
shows <UNKNOWN>.
Is there some way to setup Druid so it can display the longvarchar type
or is there some other database client out there which can read a McKoi db
and display the longvarchar type?
Andrew
You could probably do an export from druid to see the values (Export
in Druid format ddf).
HTH.
Francois
2011/1/13 andrew walsh <awalsh@anonymised.com>:
Hi GN list,
table)
shows <UNKNOWN>.
Andrew
Protect Your Site and Customers from Malware Attacks
Learn about various malware tactics and how to avoid them. Understand
malware threats, the impact they can have on your business, and how you
can protect your company and customers by using code signing.
http://p.sf.net/sfu/oracle-sfdevnl
GeoNetwork-devel mailing list
Hi Francois,
Thanks! that did the trick. Now I can properly look
at that monster 'settings' table which has longvarchar types on 'values'
Andrew
----- Original Message ----- From: "Francois Prunayre" <fx.prunayre@anonymised.com>
To: "andrew walsh" <awalsh@anonymised.com>
Cc: <geonetwork-devel@lists.sourceforge.net>; <geonetwork-users@lists.sourceforge.net>
Sent: Thursday, January 13, 2011 17:02
Subject: Re: [GeoNetwork-devel] Displaying longvarchar type from McKoi db
HTH.
Francois
Hi GN list,
table)
shows <UNKNOWN>.
Andrew
