[GeoNetwork-users] distinction between service and data metadata [SEC=UNCLASSIFIED]
The way to distinguish services metadata from other metadata is via the
hierachyLevel element. The codeListValue of this element should be
"service". You can then look at the protocol element to see what type of
service is available. That is wms, wfs, wcs, etc.
The hierarchyLevel element is mandatory if the hierarchyLevel is *not*
"dataset". Therefore is will be completed if you are describing a "service"
so it is the best element to use to identify the types of metadata records.
I hope that this helps and that I am not repeating what someone else says.
Thanks.
John
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On
Behalf Of Sebastian Schmitz
Sent: Friday, 30 May 2008 9:33 PM
To: francois-xavier.prunayre@anonymised.com
Cc: Geonetwork Users; Jeroen Ticheler
Subject: Re: [GeoNetwork-users] distinction between service
and data metadata
Francois-Xavier Prunayre schrieb:
> Hi,
> On mer, 2008-05-28 at 18:33 +0200, Jeroen Ticheler wrote:
>> Hi Sebastian,
>> Currently there's no distinguishing element as far as I know
>> (François?).
> Schema for metadata on data or service is always iso19139 but the
> identification section is different :
srv:SV_ServiceIdentification for
> service and gmd:MD_DataIdentification for data.
So that could be used to distinguish between data and
services, right?
One could query against the identification section...? I am
not yet very familiar with the iso19139 schema.
>> There is an index that filters on the content-type as
defined in the
>> ISO19115 standard, distinguishing paper from digital data,
but that
>> does not differentiate services from data. thee's also an index on
>> download (data, pdf's etc) and interactive (WMS and so) which is
>> based on the protocol field in ISO19115. The last index should
>> probably be extended by indexing service metadata (19119) as
>> interactive too. Not sure if that's planned for by
François for now.
> It is in the coming month (june or july) ... Maybe we
should also have
> an option to search for WMS, WFS, ...
I believe, allowing to search for all OWS and also allowing
to narrow that search down to a specific service type would
be a very convenient search option. ServiceType is stored in
Identification/ServiceIdentication/ServiceType/Name, right?
Any pointers on how to make that field queryable via search
GUI most welcome..
>Cheers
Sebastian
> Ciao.
> Francois
This SF.net email is sponsored by: Microsoft Defy all
challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-users mailing list
