[GeoNetwork-users] Does anyone have a Linux squeeze Postgresql 8.4 pg_dump that I could use
Sorry for cross posting.
I have been trying to migrate an instance of GeoNetwork from one
computer to another. I keep having troubles with the Postgresql
database.
The source computer is running the Debian Lenny operating system with
Postgresql 8.3. This has all the GN configuration and metadata in it.
The target computer is running the Debian Squeeze operating system with
Postgresql 8.4. This is where I would like to copy the source GN onto.
I have another development computer on which I loaded Debian Lenny and
Postgresql 8.3. I thought that I successfully loaded a pg_dumpall of the
source machine into this database. I then did an upgrade of the
operating system to Debian Squeeze which also loaded Postgresql 8.4.
I then did:
  pg_dropcluster 8.4 main; # to get rid of the new database
  pg_upgradecluster 8.3 main; #to upgrade the database to 8.4
This should have worked but I kept on getting errors about hundreds of
different tables not existing.
I then tried:
  pg_dropcluster 8.3 main; # to get rid of the old database
  pg_createcluster 8.3 main; # to create a clean 8.3 cluster
  pg_ctlcluster 8.3 main start; # to start the clean 8.3 database
  psql -f dumpfile - postgres; # to load the dumpfile from the source
When I tried to do another pg_upgradecluster 8.3 main I kept on getting
errors "Server is 8.4 library is 8.3" and then hundreds of errors like:
psql:<stdin>:320652: ERROR: type "geometry" is only a shell
psql:<stdin>:320664: ERROR: aggregate public.accum(geometry) does not
exist
What I would like is a dump of some ones Postgresql 8.4 database created
on a Debian Squeeze operating system for GN 2.7 snapshot. Can anyone
provide this or suggest something else that could help?
Thanks.
John Hockaday
Hi Jesse,
Thanks for the prompt reply. Please see comments in line below:
On Wed, 2012-05-23 at 08:20 +0200, Jesse Eichar wrote:
I had a similar problem caused by the fact that I was using postgis
and when I upgraded I needed to install the new version of postgis.
The way I did it was terrible but it worked :).
Any solution that works will be good. ;--)
One note, GeoNetwork pollutes the main schema with its tables which is
a bit unfortunate when upgrading postgres versions and it would be
nice to one day make this configurable. But that is another story.
So my upgrade workflow when I had this problem:
1. pg_dump ....
Done.
2. create database in new postgres version
Is there another way to do this other than pg_createcluster 8.4 main?
Is it a GN database or just the cluster? If the former where can I get
the SQL commands to make the tables and functions?
3. manually install postgis into the new database
I tried 'sudo apt-get update postgis' and I got postgis is already the
latest version.
4. add dump back
Step for resulting in lots of errors but no rollbacks. and in the end
it worked. The errors were all of the sort Geometry already exists.
I too get a lot of errors. Can I ignore these and hope that GN will
still work?
I seem to have lost the metadata but I hope I can harvest it from the
original GN server.
Thanks in advance for any help you can provide.
JohnH
These errors were caused by the fact that I had already installed
postgis functions, objects, etc... But this was required because of
the differing versions. In the end this worked.
Maybe this will help you, maybe not but it is worth a try.
Jesse
On Wed, May 23, 2012 at 1:18 AM, john.hockaday
<john.hockaday@anonymised.com> wrote:
        one
        Postgresql
        database.
        system with
        in it.
        system with
        GN onto.
        Lenny and
        pg_dumpall of the
        the
        Postgresql 8.4.
        I then did:
        hundreds of
        I then tried:
        database
        source
        on getting
        errors like:
        does not
        exist
        database created
        anyone
        Thanks.
        John Hockaday
        Live Security Virtual Conference
        Exclusive live event will cover all the ways today's security
        and
        threat landscape has changed and how IT managers can respond.
        Discussions
        will include endpoint security, mobile security and the latest
        in malware
        threats.
        http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
        GeoNetwork-devel mailing list
I had a similar problem caused by the fact that I was using postgis and when I upgraded I needed to install the new version of postgis. The way I did it was terrible but it worked :).
One note, GeoNetwork pollutes the main schema with its tables which is a bit unfortunate when upgrading postgres versions and it would be nice to one day make this configurable. But that is another story.
  1. pg_dump …
  4. add dump back
Step for resulting in lots of errors but no rollbacks. and in the end it worked. The errors were all of the sort Geometry already exists.
These errors were caused by the fact that I had already installed postgis functions, objects, etc… But this was required because of the differing versions. In the end this worked.
Jesse
On Wed, May 23, 2012 at 1:18 AM, john.hockaday <john.hockaday@anonymised.com…> wrote:
database.
I then did:
I then tried:
errors “Server is 8.4 library is 8.3” and then hundreds of errors like:
psql::320652: ERROR: type “geometry” is only a shell
psql::320664: ERROR: aggregate public.accum(geometry) does not
exist
Thanks.
John Hockaday
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
I guess the big difference is that I was dealing with a single database so
pg_dump -U www-data -E UTF-8 -Z 9 geocat2 > $DUMP_FILE
was sufficient for me.
for cluster… sorry to say I am out of ideas. I think you need to go to the postgis users list.
Jesse
On Fri, May 25, 2012 at 1:42 AM, john.hockaday <john.hockaday@anonymised.com> wrote:
Hi Jesse,
Any solution that works will be good. ;–)
  1. pg_dump …
Done.
  1. create database in new postgres version
  1. manually install postgis into the new database
I tried ‘sudo apt-get update postgis’ and I got postgis is already the
latest version.
  1. add dump back
still work?
original GN server.
JohnH
Jesse
one
Postgresql
database.
system with
in it.
system with
GN onto.
Lenny and
pg_dumpall of the
the
Postgresql 8.4.
I then did:
hundreds of
I then tried:
database
source
on getting
errors like:
does not
exist
database created
anyone
Thanks.
John Hockaday
and
Discussions
in malware
threats.
