Hi All,
I am having a problem while implementing the *eml-gbif schema* in
*Geonetwork 3.4*, It showing blank template and not reponding. I tried all
the steps provided in schema implementation guide using the
https://github.com/geonetwork/schema-plugins-no-history/tree/master/eml-gbif
<https://github.com/geonetwork/schema-plugins-no-history/tree/master/eml-gbif>
. In earlier version of *Geonetwork 2.10.3* it was working fine. I am trying
to migrate from Geonetwork 2.10.3 to Geonetwork 3.4 but stuck in using
eml-gbif schema. I have list of metadata that uses eml-gbif schema in
previous version of Geonetwork 2.10.3.
Any help/suggestion will be much appreciated, Thank you.
Sameer
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Hi Sameer, this schema has not been maintained for 3.4 so if you want to
update it you could have a look to
https://geonetwork-opensource.org/manuals/3.4.x/en/customizing-application/implementing-a-schema-plugin.html
and see how other schemas are working.
HTH
Francois
Le mar. 15 mai 2018 à 08:25, SameerBajra <sameer.bajracharya@anonymised.com> a
écrit :
Hi All,
trying
Sameer
Sent from:
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
