Hi Jeroen,
The other area where Fast Infoset is useful is for processing large XML
documents.
Thanks.
John
-----Original Message-----
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Sent: Thursday, 12 October 2006 7:00 PM
To: Hockaday John
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Does GeoNetwork use InfoSet
and Fast Infoset?Hi John,
Thanks for the interesting idea. I have added it to my GN 3 planning
list as something that could be investigated further. I understand
the main benefit is there where XML is to be send between a server
and a client!? This could for instance be relevant in harvesting
services or as you mention distributed searches.
If you referred to distributed searches through Z39.50 I think the
time delay is mainly caused by the waiting time for remote
servers to
respond, hence the time out option.
Ciao,
JeroenOn Oct 12, 2006, at 3:40 AM, John.Hockaday@anonymised.com wrote:
> Hi All,
> I have noticed that distributed searches often take a long time to
> return
> information to GeoNetwork. Is this possibly due to the processing
> of the XML
> or is it likely to be the bandwidth? If it is the former then maybe
> GeoNetwork would benefit from using Fast Infoset if it doesn't
> already do so.
> I would expect that the XML sent to the servers would be small and
> therefore
> wouldn't benefit from using Fast Infoset but the XML information
> that is
> returned from the servers could be quite large. If this is the
> case then
> maybe requesting Fast Infoset from the servers may expedite the
> returned
> response, reduce bandwidth and make the processing on the client
> faster (if
> the client can process Fast Infoset).
> I haven't investigated the benefits of using Fast Infoset
for typical
> GeoNetwork processes but maybe it could be a consideration if
> GeoNetwork
> doesn't already use it.
> It would certainly be useful if GeoNetwork processes information
> from WFS
> where the returned XML is likely to be huge.
> Just a thought of mine to share with you.
> Thanks.
> John
> Using Tomcat but need to do more? Need to support web services,
> security?
> Get stuff done quickly with pre-integrated technology to make your
> job easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache
> Geronimo
> http://sel.as-us.falkag.net/sel?
> cmd=lnk&kid=120709&bid=263057&dat=121642
> GeoNetwork-users mailing list
> GeoNetwork-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> GeoNetwork OpenSource is maintained at http://sourceforge.net/
> projects/geonetwork
