As a user I would like to have the metadata handy when I download a dataset. Suggestion is to include the metadata with the shapefile, gml or kml dataset that I download directly from geonetwork.
Suggestion to implement this is to be able to run a wizard so that you can specify what data you want to download and have an option to include the metadata file?
Any thoughts?
2015-06-05 16:00 GMT+02:00 Bloemscheer, Jeroen <jeroen.bloemscheer@anonymised.com>:
metadata file?
Any thoughts?
We used to have some kind of wizard to do a custom package from the
metadata (and associated resources) and generating a licence file based on
the metadata constraints.
Would be good to migrate those services/ui in the Angular app. I think it
was
https://github.com/geonetwork/core-geonetwork/blob/3.0.x/web/src/main/webapp/WEB-INF/config.xml#L139
HTH.
Francois
GeoNetwork-users mailing list
