Thanks all who have responded so far, I will respond to each in this email:
I am not sure if we are doing things very differently here to how others do
it but we create ISO19139 compliant XML files using a separate system which
are currently being uploaded into an Oracle system and just being stored as
an XML object, however the end user has a requirement to publish the
metadata so more people have access to the information. Having looked
around we decided GeoNetwork would be suitable to do that so we are working
out the process to get the data from the XML files into GeoNetwork and the
batch process works well, other than there is no checking to see if it
already exists in the db.
Jason/ A. Soroka,
It is to guard against the potential. We are setting up a system which will
allow a variety of people to upload metadata so there is the potential that
two different people could upload the same metadata (it would be the same
XML file uploaded twice). As the Batch Import just does all files in the
specified folder someone could have left a file in there that had already
been uploaded, or even just by accidentally clicking Go on the Batch Import
it would do it again.
Heikki,
I would certainly think it would be useful, but maybe I am the only one who
doesn't trust their users!!!
Andrew,
We are intending to use PostGreSQL in the background (which I am also a
newbie with) so maybe they have similar setup, will investigate that,
thanks.
Thanks all, and any further ideas are always welcome.
Caroline
-----Original Message-----
Sent: 08 September 2009 00:25
To: Caroline Levey
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Duplication of records
Caroline,
I think if you use the default database provided with GN which is McKoi it
lets you have records with duplicate fileIdentifiers (uuid) in the database.
However yif ou use a database like Oracle it won't let you upload records
with duplicate identifier. Maybe this could help you.
Andrew
----- Original Message -----
From: "Caroline Levey" <Caroline.Levey@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>
Sent: Monday, September 07, 2009 9:25 PM
Subject: [GeoNetwork-users] Duplication of records
Hi
I am new at this Geonetwork thing so this may be a really dumb question,
sorry if that is so!
I have successfully got my little geonetwork site running but have
discovered it is very easy to add the same metadata records more than
once,
so they then appear twice in the results list. Is there a way to prevent
this happening within the software? I am generally using the Batch Upload
for XML files. I couldn't find anything obvious in the manual for this.
Any help/suggestions would be much appreciated.
Thanks very much
Caroline Levey
Senior GIS Developer
SeaZone Solutions Limited
SeaZone provides Marine Geographic Information Solutions from instrument
to
desktop, supporting decision making in the Marine Environment and Coastal
Zone
BETTER DATA, BETTER SCIENCE, IMPROVED DECISIONS<
Tel: +44 (0) 870 013 0607
Fax: +44 (0) 870 013 0608
Email: caroline.levey@anonymised.com <mailto:info@anonymised.com>
Web: www.SeaZone.com <http://www.seazone.com/>
Post: Red Lion House, Bentley, Hampshire GU10 5HY, United Kingdom
Registered in England and Wales: No. 4969561.
Registered Office: Admiralty Way, Taunton, Somerset, TA1 2DN
This email and any files transmitted with it are confidential
and intended only for the use by the addressee. If you
receive this email by mistake pleases notify SeaZone
immediately.
Let Crystal Reports handle the reporting - Free Crystal Reports 2008
30-Day
trial. Simplify your report design, integration and deployment - and focus
on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-users mailing list
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
on
