Good afternoon,
I installed the Geonetwork 3.0.1, I'm in the Spanish language, when I need
edit metadata, do not appear the fields. In the log I get the following:
2015-07-14 16:52:27,387 WARN
[org.springframework.context.support.ResourceBundleMessageSource] -
ResourceBundle [messages] not found for MessageSource: Can't find bundle for
base name messages, locale eng
2015-07-14 16:52:36,124 ERROR [jeeves.resources] - Error cloning the cached
data. Attempted to get:
/opt/tomcat/webapps/geonetwork/loc/spa/xml/i18n.xmlbut failed so falling
back to default language
2015-07-14 16:52:41,473 WARN
2015-07-14 16:52:44,846 ERROR [jeeves.resources] - Error cloning the cached
2015-07-14 16:52:46,071 ERROR [jeeves.service] - -> exception during
transformation for : md.edit
2015-07-14 16:52:46,071 ERROR [jeeves.service] - -> (C) stylesheet :
/opt/tomcat/webapps/geonetwork/xsl/../xslt/ui-metadata/edit/edit.xsl
2015-07-14 16:52:46,071 ERROR [jeeves.service] - -> (C) message : An
empty sequence is not allowed as the value of parameter $overrideLabel
2015-07-14 16:52:46,071 ERROR [jeeves.service] - -> (C) exception :
XPathException
I can do?
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/Edit-metadata-languaje-spanish-tp5215628.html
Hi
I get a similar error in the log with the missing file /loc/spa/xml/i18n.xml,
but for me the metadata can be edited and fields appear.
I see that i18n.xml file seem only available for english and french, but at
least according to the message, if not found in other languages should
default to english.
Jose García
On Tue, Jul 14, 2015 at 11:54 PM, cbeltran <cbeltran@anonymised.com> wrote:
Good afternoon,
for
for
XPathException
I can do?
Thanks
Don't Limit Your Business. Reach for the Cloud.
GigeNET's Cloud Solutions provide you with the tools and support that
you need to offload your IT needs and focus on growing your business.
Configured For All Businesses. Start Your Cloud Today.
https://www.gigenetcloud.com/
GeoNetwork-users mailing list
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/> for
details. _________________________Jose GarcíaGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
2015-07-15 8:39 GMT+02:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
default to english.
Jose García
wrote:
> Good afternoon,
need
> for
cached
> for
cached
An
This error probably means that your metadata record contains something
which is not properly handled by the form builder. Is this a default
template provided ? If not, could you provide your record using
http://localhost:8080/geonetwork/srv/eng/catalog.edit#/metadata/5649/tab/xml
to access the XML view of the editor and then we could try to reproduce the
issue.
Thanks.
Francois
> XPathException
> I can do?
> Thanks
Hi Jose and Francois
Thanks for your replies
I probe XML View, this is the log:
2015-07-15 08:54:04,631 ERROR [jeeves.resources] - Error cloning the cached
2015-07-15 08:54:14,435 ERROR [jeeves.resources] - Error cloning the cached
2015-07-15 08:54:15,663 ERROR [jeeves.service] - -> exception during
2015-07-15 08:54:15,663 ERROR [jeeves.service] - -> (C) stylesheet :
2015-07-15 08:54:15,663 ERROR [jeeves.service] - -> (C) message : An
2015-07-15 08:54:15,664 ERROR [jeeves.service] - -> (C) exception :
XPathException
2015-07-15 08:54:28,394 ERROR [jeeves.resources] - Error cloning the cached
<http://osgeo-org.1560.x6.nabble.com/file/n5215747/viewxml.png>
Attach picture with edit in spanish and english language
<http://osgeo-org.1560.x6.nabble.com/file/n5215747/editmetadata.png>
<http://osgeo-org.1560.x6.nabble.com/file/n5215747/editmetadata2.png>
language English it works
<http://osgeo-org.1560.x6.nabble.com/file/n5215747/editmetadata3.png>
The schema used is ISO_19139
Regards...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Edit-metadata-languaje-spanish-tp5215628p5215747.html
Would be good to provide the XML and not only screenshot so that we could
try to reproduce.
Thanks.
Francois
2015-07-15 15:58 GMT+02:00 cbeltran <cbeltran@anonymised.com>:
XPathException
Regards...
Hi, attach the xml metadata
<gmd:MD_Metadata xmlns:gmd="http://www.isotc211.org/2005/gmd"
xmlns:gco="http://www.isotc211.org/2005/gco"
xmlns:gts="http://www.isotc211.org/2005/gts"
xmlns:srv="http://www.isotc211.org/2005/srv"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:geonet="http://www.fao.org/geonetwork">
<gmd:fileIdentifier>
<gco:CharacterString>242fd83f-bf75-4392-89a8-88d9bc030d2e</gco:CharacterString>
</gmd:fileIdentifier>
<gmd:language>
<gmd:LanguageCode codeList="http://www.loc.gov/standards/iso639-2/"
codeListValue="eng"
codeSpace="ISO639-2"/>
</gmd:language>
<gmd:characterSet>
<gmd:MD_CharacterSetCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#MD_CharacterSetCode"
codeListValue="utf8"
codeSpace="ISOTC211/19115"/>
</gmd:characterSet>
<gmd:hierarchyLevel>
<gmd:MD_ScopeCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#MD_ScopeCode"
codeListValue="dataset"
</gmd:hierarchyLevel>
<gmd:hierarchyLevelName>
<gco:CharacterString>dataset</gco:CharacterString>
</gmd:hierarchyLevelName>
<gmd:contact>
<gmd:CI_ResponsibleParty>
<gmd:individualName>
<gco:CharacterString>Juliana Rodriguez - Edersson
Cabrera</gco:CharacterString>
</gmd:individualName>
<gmd:organisationName>
<gco:CharacterString>Instituto de Investigación de Recursos
Biológicos Alexander von Humboldt</gco:CharacterString>
</gmd:organisationName>
<gmd:positionName>
<gco:CharacterString>Administradora información geográfica -
Investigador</gco:CharacterString>
</gmd:positionName>
<gmd:contactInfo>
<gmd:CI_Contact>
<gmd:phone>
<gmd:CI_Telephone>
<gmd:voice>
<gco:CharacterString>+57 1
3202767</gco:CharacterString>
</gmd:voice>
<gmd:facsimile>
</gmd:facsimile>
</gmd:CI_Telephone>
</gmd:phone>
<gmd:address>
<gmd:CI_Address>
<gmd:deliveryPoint>
<gco:CharacterString>Claustro de San
Agustín</gco:CharacterString>
</gmd:deliveryPoint>
<gmd:city>
<gco:CharacterString>Villa de
Leyva</gco:CharacterString>
</gmd:city>
<gmd:administrativeArea>
<gco:CharacterString>Boyacá</gco:CharacterString>
</gmd:administrativeArea>
<gmd:postalCode>
<gco:CharacterString>99999</gco:CharacterString>
</gmd:postalCode>
<gmd:country>
<gmd:Country
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#Country"
codeListValue="CO"
codeSpace="ISO3166-1"/>
</gmd:country>
<gmd:electronicMailAddress>
<gco:CharacterString>unisig@anonymised.com</gco:CharacterString>
</gmd:electronicMailAddress>
</gmd:CI_Address>
</gmd:address>
<gmd:hoursOfService>
<gco:CharacterString>8 - 12 AM, 2 - 5
PM</gco:CharacterString>
</gmd:hoursOfService>
</gmd:CI_Contact>
</gmd:contactInfo>
<gmd:role>
<gmd:CI_RoleCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#CI_RoleCode"
codeListValue="pointOfContact"/>
</gmd:role>
</gmd:CI_ResponsibleParty>
</gmd:contact>
<gmd:contact>
<gco:CharacterString>Edwin Tamayo</gco:CharacterString>
<gmd:contactInfo>
<gmd:CI_Contact>
<gmd:address>
<gmd:CI_Address>
<gmd:electronicMailAddress gco:nilReason="missing">
<gco:CharacterString/>
</gmd:CI_Address>
</gmd:address>
</gmd:CI_Contact>
</gmd:contactInfo>
<gmd:role>
<gmd:CI_RoleCode
</gmd:role>
</gmd:contact>
<gmd:dateStamp>
<gco:DateTime>2015-07-14T16:30:57</gco:DateTime>
</gmd:dateStamp>
<gmd:metadataStandardName>
<gco:CharacterString>ISO 19139 Geographic Information - Metadata -
Implementation Specification</gco:CharacterString>
</gmd:metadataStandardName>
<gmd:metadataStandardVersion>
<gco:CharacterString>2007</gco:CharacterString>
</gmd:metadataStandardVersion>
<gmd:spatialRepresentationInfo>
<gmd:MD_Georectified>
<gmd:numberOfDimensions>
<gco:Integer>2</gco:Integer>
</gmd:numberOfDimensions>
<gmd:axisDimensionProperties>
<gmd:MD_Dimension>
<gmd:dimensionName>
<gmd:MD_DimensionNameTypeCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#MD_DimensionNameTypeCode"
codeListValue="column"
</gmd:dimensionName>
<gmd:dimensionSize>
<gco:Integer>23180</gco:Integer>
</gmd:dimensionSize>
<gmd:resolution>
<gco:Measure uom="Meter">32.355173</gco:Measure>
</gmd:resolution>
</gmd:MD_Dimension>
</gmd:axisDimensionProperties>
<gmd:MD_Dimension>
<gmd:dimensionName>
codeListValue="row"
<gmd:dimensionSize>
<gco:Integer>37092</gco:Integer>
<gmd:resolution>
</gmd:resolution>
</gmd:MD_Dimension>
<gmd:cellGeometry>
<gmd:MD_CellGeometryCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#MD_CellGeometryCode"
codeListValue="area"
</gmd:cellGeometry>
<gmd:transformationParameterAvailability>
<gco:Boolean>true</gco:Boolean>
</gmd:transformationParameterAvailability>
<gmd:checkPointAvailability>
<gco:Boolean>false</gco:Boolean>
</gmd:checkPointAvailability>
<gmd:cornerPoints>
<gml:Point gml:id="ID0EDCAE">
<gml:pos>1256879.596035 1731969.999732</gml:pos>
</gml:Point>
</gmd:cornerPoints>
<gmd:cornerPoints>
<gml:Point gml:id="ID0EJCAE">
<gml:pos>1256879.596035 531851.906161</gml:pos>
</gml:Point>
</gmd:cornerPoints>
<gmd:cornerPoints>
<gml:Point gml:id="ID0EXBAE">
<gml:pos>506886.675487 531851.906161</gml:pos>
</gml:Point>
</gmd:cornerPoints>
<gmd:cornerPoints>
<gml:Point gml:id="ID0E4BAE">
<gml:pos>506886.675487 1731969.999732</gml:pos>
</gml:Point>
</gmd:cornerPoints>
<gmd:centerPoint>
<gml:Point gml:id="ID0EPCAE">
<gml:pos>881883.135761 1131910.952947</gml:pos>
</gml:Point>
</gmd:centerPoint>
<gmd:pointInPixel>
<gmd:MD_PixelOrientationCode>center</gmd:MD_PixelOrientationCode>
</gmd:pointInPixel>
</gmd:MD_Georectified>
</gmd:spatialRepresentationInfo>
<gmd:referenceSystemInfo>
<gmd:MD_ReferenceSystem>
<gmd:referenceSystemIdentifier>
<gmd:RS_Identifier>
<gmd:code>
<gco:CharacterString>3116</gco:CharacterString>
</gmd:code>
<gmd:codeSpace>
<gco:CharacterString>EPSG</gco:CharacterString>
</gmd:codeSpace>
<gmd:version>
<gco:CharacterString>8.1.1</gco:CharacterString>
</gmd:version>
</gmd:RS_Identifier>
</gmd:referenceSystemIdentifier>
</gmd:MD_ReferenceSystem>
</gmd:referenceSystemInfo>
<gmd:identificationInfo>
<gmd:MD_DataIdentification>
<gmd:citation>
<gmd:CI_Citation>
<gmd:title>
<gco:CharacterString>Ecosistemas de los Andes Colombianos
para el año 2000, escala 1:250.000</gco:CharacterString>
</gmd:title>
<gmd:date gco:nilReason="missing"/>
<gmd:citedResponsibleParty>
Recursos Biológicos Alexander von Humboldt</gco:CharacterString>
<gmd:role>
<gmd:CI_RoleCode
codeListValue="originator"
</gmd:role>
</gmd:citedResponsibleParty>
<gmd:positionName>
geográfica - Investigador</gco:CharacterString>
</gmd:positionName>
<gmd:contactInfo>
<gmd:CI_Contact>
<gmd:phone>
<gmd:CI_Telephone>
<gmd:voice>
</gmd:voice>
<gmd:facsimile>
</gmd:facsimile>
</gmd:CI_Telephone>
</gmd:phone>
<gmd:address>
<gmd:CI_Address>
<gmd:deliveryPoint>
<gmd:city>
</gmd:city>
<gmd:postalCode>
</gmd:postalCode>
<gmd:country>
<gmd:Country
codeListValue="CO"
</gmd:country>
</gmd:CI_Address>
</gmd:address>
</gmd:CI_Contact>
</gmd:contactInfo>
<gmd:role>
<gmd:CI_RoleCode
</gmd:role>
Peña</gco:CharacterString>
<gmd:contactInfo>
<gmd:CI_Contact>
<gmd:phone>
<gmd:CI_Telephone>
<gmd:voice>
</gmd:voice>
<gmd:facsimile>
</gmd:facsimile>
</gmd:CI_Telephone>
</gmd:phone>
<gmd:address>
<gmd:CI_Address>
<gmd:deliveryPoint>
<gmd:city>
</gmd:city>
<gmd:postalCode>
</gmd:postalCode>
<gmd:country>
<gmd:Country
codeListValue="CO"
</gmd:country>
</gmd:CI_Address>
</gmd:address>
</gmd:CI_Contact>
</gmd:contactInfo>
<gmd:role>
<gmd:CI_RoleCode
</gmd:role>
<gmd:presentationForm>
<gmd:CI_PresentationFormCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#CI_PresentationFormCode"
codeListValue="mapDigital"
</gmd:presentationForm>
</gmd:CI_Citation>
</gmd:citation>
<gmd:abstract>
<gco:CharacterString>Mapa de Ecosistemas de los Andes
Colombianos del año 2000, escala 1:250.000. Proyecto desarrollado en el
proyecto "Conservación y Uso Sostenible de los Andes Colombianos",
desarrollado por el Instituto de Investigación de Recursos Biológicos
Alexander von Humboldt y financiado por el Fondo Ambiental Global (GEF), el
Banco Mundial (WB) y la Embajada Real de los Países
Bajos.</gco:CharacterString>
</gmd:abstract>
<gmd:purpose>
<gco:CharacterString>Servir como base para la incorporación de
nueva información con el fin de lograr una mayor comprensión y utilización
de los ecosistemas (y por ende de la biodiversidad) en esta región del
país.</gco:CharacterString>
</gmd:purpose>
<gmd:credit>
<gco:CharacterString>Copyright © IAvH 2006. Ecosistemas de los
Andes Colombianos del año 2000, escala 1:250.000. Proyecto Conservación y
uso sostenible de la biodiversidad en los Andes colombianos. Bogotá, D. C.,
Colombia.</gco:CharacterString>
</gmd:credit>
<gmd:status>
<gmd:MD_ProgressCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#MD_ProgressCode"
codeListValue="completed"
</gmd:status>
<gmd:pointOfContact>
<gco:CharacterString>Administrador información
geoespacial</gco:CharacterString>
<gmd:positionName>
<gco:CharacterString>Infraestructura Institucional de
Datos - I2D</gco:CharacterString>
</gmd:positionName>
<gmd:contactInfo>
<gmd:CI_Contact>
<gmd:phone>
<gmd:CI_Telephone>
<gmd:voice>
</gmd:voice>
<gmd:facsimile>
</gmd:facsimile>
</gmd:CI_Telephone>
</gmd:phone>
<gmd:address>
<gmd:CI_Address>
<gmd:deliveryPoint>
<gmd:city>
</gmd:city>
<gmd:postalCode>
</gmd:postalCode>
<gmd:country>
<gmd:Country
codeListValue="CO"
</gmd:country>
</gmd:CI_Address>
</gmd:address>
</gmd:CI_Contact>
</gmd:contactInfo>
<gmd:role>
<gmd:CI_RoleCode
</gmd:role>
</gmd:pointOfContact>
<gmd:resourceMaintenance>
<gmd:MD_MaintenanceInformation>
<gmd:maintenanceAndUpdateFrequency>
<gmd:MD_MaintenanceFrequencyCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#MD_MaintenanceFrequencyCode"
codeListValue="notPlanned"
</gmd:maintenanceAndUpdateFrequency>
</gmd:MD_MaintenanceInformation>
</gmd:resourceMaintenance>
<gmd:graphicOverview>
<gmd:MD_BrowseGraphic>
<gmd:fileName>
<gco:CharacterString>http://geonetwork.humboldt.org.co:80/geonetwork/srv/eng/resources.get?uuid=242fd83f-bf75-4392-89a8-88d9bc030d2e&fname=elim_ecos2000_magnasirgas_s.png</gco:CharacterString>
</gmd:fileName>
<gmd:fileDescription>
<gco:CharacterString>thumbnail</gco:CharacterString>
</gmd:fileDescription>
<gmd:fileType>
<gco:CharacterString>png</gco:CharacterString>
</gmd:fileType>
</gmd:MD_BrowseGraphic>
</gmd:graphicOverview>
<gmd:fileName>
<gco:CharacterString>http://geonetwork.humboldt.org.co:80/geonetwork/srv/eng/resources.get?uuid=242fd83f-bf75-4392-89a8-88d9bc030d2e&fname=elim_ecos2000_magnasirgas.jpg</gco:CharacterString>
</gmd:fileName>
<gco:CharacterString>large_thumbnail</gco:CharacterString>
<gmd:fileType>
<gco:CharacterString>jpg</gco:CharacterString>
</gmd:fileType>
<gmd:descriptiveKeywords>
<gmd:MD_Keywords>
<gmd:keyword>
<gco:CharacterString>Sur America</gco:CharacterString>
</gmd:keyword>
<gmd:keyword>
<gco:CharacterString>Colombia</gco:CharacterString>
</gmd:keyword>
<gmd:keyword>
<gco:CharacterString>Andes</gco:CharacterString>
</gmd:keyword>
<gmd:type>
<gmd:MD_KeywordTypeCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#MD_KeywordTypeCode"
codeListValue="place"
</gmd:type>
</gmd:MD_Keywords>
</gmd:descriptiveKeywords>
<gmd:MD_Keywords>
<gmd:keyword>
<gco:CharacterString>2000</gco:CharacterString>
</gmd:keyword>
<gmd:type>
codeListValue="temporal"
</gmd:type>
</gmd:MD_Keywords>
<gmd:MD_Keywords>
<gmd:keyword>
<gco:CharacterString>Ecosistemas, Biodiversidad,
DTM</gco:CharacterString>
</gmd:keyword>
<gmd:type>
codeListValue="theme"
</gmd:type>
</gmd:MD_Keywords>
<gmd:MD_Keywords>
<gmd:keyword>
<gco:CharacterString>Downloadable
Data</gco:CharacterString>
</gmd:keyword>
<gmd:thesaurusName
uuidref="723f6998-058e-11dc-8314-0800200c9a66"/>
</gmd:MD_Keywords>
<gmd:resourceConstraints>
<gmd:MD_Constraints>
<gmd:useLimitation>
<gco:CharacterString>El usuario de la información se
compromete a: 1. Utilizar la información únicamente para los fines
autorizados. 2. Respetar y hacer valer frente a terceros los derechos de
propiedad de los autores. 3. No distribuir la información a terceros sin
previa autorización de los autores. 4. Dar créditos a los autores en todos
los productos derivados del uso de la información. 5. No realizar
modificaciones, ni incluir logos - símbolos o publicidad diferente a aquella
que permita identificar la fuente de la información entregada. 6. No
comercializar. 7. Responder por la correcta utilización de la información.
8. Asumir la responsabilidad del uso del software empleado en los análisis y
de los resultados obtenidos. 9. Entregar al Instituto Humboldt, copias
digitales de los productos que resulten de la cartografía entregada (cuando
aplique). 10. No ceder las obligaciones adquiridas.</gco:CharacterString>
</gmd:useLimitation>
</gmd:MD_Constraints>
</gmd:resourceConstraints>
<gmd:MD_LegalConstraints>
<gmd:useLimitation>
<gmd:otherConstraints>
<gco:CharacterString>Realizar solicitud formal de la
información al Instituto Humboldt, una vez evaluada y aprobada, se procede a
su entrega previa aceptación y cumplimiento de los compromisos establecidos,
los cuales se mencionan dentro de las limitaciones de
uso.</gco:CharacterString>
</gmd:otherConstraints>
</gmd:MD_LegalConstraints>
<gmd:MD_SecurityConstraints>
<gmd:classification>
<gmd:MD_ClassificationCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#MD_ClassificationCode"
codeListValue="restricted"
</gmd:classification>
</gmd:MD_SecurityConstraints>
<gmd:spatialRepresentationType>
<gmd:MD_SpatialRepresentationTypeCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#MD_SpatialRepresentationTypeCode"
codeListValue="grid"
</gmd:spatialRepresentationType>
<gmd:spatialResolution>
<gmd:MD_Resolution>
<gmd:equivalentScale>
<gmd:MD_RepresentativeFraction>
<gmd:denominator>
<gco:Integer>250000</gco:Integer>
</gmd:denominator>
</gmd:MD_RepresentativeFraction>
</gmd:equivalentScale>
</gmd:MD_Resolution>
</gmd:spatialResolution>
<gmd:language>
<gmd:LanguageCode
codeList="http://www.loc.gov/standards/iso639-2/" codeListValue="spa"
</gmd:language>
<gmd:characterSet>
</gmd:characterSet>
<gmd:topicCategory>
<gmd:MD_TopicCategoryCode>environment</gmd:MD_TopicCategoryCode>
</gmd:topicCategory>
<gmd:environmentDescription>
<gco:CharacterString>Version 6.2 (Build 9200) ; Esri ArcGIS
10.2.0.3345</gco:CharacterString>
</gmd:environmentDescription>
<gmd:extent>
<gmd:EX_Extent>
<gmd:description>
<gco:CharacterString>ground
condition</gco:CharacterString>
</gmd:description>
<gmd:temporalElement xmlns:gn="http://www.fao.org/geonetwork"
xmlns:gmx="http://www.isotc211.org/2005/gmx">
<gmd:EX_TemporalExtent>
<gmd:extent>
<gml:TimePeriod gml:id="d12879e583a1050910">
<gml:beginPosition/>
</gml:TimePeriod>
</gmd:extent>
</gmd:EX_TemporalExtent>
</gmd:temporalElement>
</gmd:EX_Extent>
</gmd:extent>
<gmd:extent>
<gmd:EX_Extent>
<gmd:geographicElement>
<gmd:EX_GeographicBoundingBox>
<gmd:extentTypeCode>
</gmd:extentTypeCode>
<gmd:westBoundLongitude>
<gco:Decimal>-78.586477</gco:Decimal>
</gmd:westBoundLongitude>
<gmd:eastBoundLongitude>
<gco:Decimal>-71.725014</gco:Decimal>
</gmd:eastBoundLongitude>
<gmd:southBoundLatitude>
<gco:Decimal>0.361374</gco:Decimal>
</gmd:southBoundLatitude>
<gmd:northBoundLatitude>
<gco:Decimal>11.213582</gco:Decimal>
</gmd:northBoundLatitude>
</gmd:EX_GeographicBoundingBox>
</gmd:geographicElement>
</gmd:EX_Extent>
</gmd:extent>
<gmd:supplementalInformation>
<gco:CharacterString>Contiene las unidades ecosistémicas que se
reconocen a la escala de análisis, de acuerdo con la metodología
desarrollada con base en el conocimiento actual de la región. El ecosistema
se entiende como una unidad funcional relativamente homogénea de organismos
que obran recíprocamente, de procesos ecológicos y de elementos geofísicos
tales como suelo, clima y régimen del agua.</gco:CharacterString>
</gmd:supplementalInformation>
</gmd:MD_DataIdentification>
</gmd:identificationInfo>
<gmd:contentInfo>
<gmd:MD_CoverageDescription>
<gmd:attributeDescription gco:nilReason="missing"/>
<gmd:contentType>
<gmd:MD_CoverageContentTypeCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#MD_CoverageContentTypeCode"
codeListValue="thematicClassification"
</gmd:contentType>
<gmd:dimension>
<gmd:MD_Band>
<gmd:descriptor>
<gco:CharacterString>Layer_1</gco:CharacterString>
</gmd:descriptor>
<gmd:maxValue>
<gco:Real>374</gco:Real>
</gmd:maxValue>
<gmd:minValue>
<gco:Real>0</gco:Real>
</gmd:minValue>
<gmd:units>
<gml:UnitDefinition gml:id="ID0EFHAE">
<gml:identifier codeSpace="GML_UomSymbol">Unified Code
of Units of Measure</gml:identifier>
</gml:UnitDefinition>
</gmd:units>
<gmd:bitsPerValue>
<gco:Integer>16</gco:Integer>
</gmd:bitsPerValue>
</gmd:MD_Band>
</gmd:dimension>
</gmd:MD_CoverageDescription>
</gmd:contentInfo>
<gmd:distributionInfo xmlns:date="http://exslt.org/dates-and-times">
<gmd:MD_Distribution>
<gmd:distributionFormat>
<gmd:MD_Format>
<gmd:name>
<gco:CharacterString>Raster Dataset</gco:CharacterString>
</gmd:name>
<gmd:version>
<gco:CharacterString>10</gco:CharacterString>
</gmd:version>
</gmd:MD_Format>
</gmd:distributionFormat>
<gmd:transferOptions>
<gmd:MD_DigitalTransferOptions>
<gmd:onLine>
<gmd:CI_OnlineResource>
<gmd:linkage>
<gmd:URL>http://192.168.16.39:8080/geonetwork/srv/eng/resources.get?uuid=242fd83f-bf75-4392-89a8-88d9bc030d2e&fname=Ecosistemas_Andes_2000.7z&access=public</gmd:URL>
</gmd:linkage>
<gmd:protocol>
<gco:CharacterString>WWW:DOWNLOAD-1.0-http--download</gco:CharacterString>
</gmd:protocol>
<gmd:name>
<gmx:MimeFileType
type="application/x-7z-compressed">Ecosistemas_Andes_2000.7z</gmx:MimeFileType>
</gmd:name>
<gmd:description>
</gmd:description>
</gmd:CI_OnlineResource>
</gmd:onLine>
</gmd:MD_DigitalTransferOptions>
</gmd:transferOptions>
</gmd:MD_Distribution>
</gmd:distributionInfo>
<gmd:dataQualityInfo>
<gmd:DQ_DataQuality>
<gmd:scope>
<gmd:DQ_Scope>
<gmd:level>
<gmd:MD_ScopeCode
</gmd:level>
</gmd:DQ_Scope>
</gmd:scope>
<gmd:report>
<gmd:DQ_DomainConsistency>
<gmd:result xmlns:gn="http://www.fao.org/geonetwork"
<gmd:DQ_ConformanceResult>
<gmd:specification>
<gmd:CI_Citation>
<gmd:title gco:nilReason="missing">
</gmd:title>
<gmd:date>
<gmd:CI_Date>
<gmd:date>
<gco:Date/>
</gmd:date>
<gmd:dateType>
<gmd:CI_DateTypeCode
codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#CI_DateTypeCode"
codeListValue="publication"/>
</gmd:dateType>
</gmd:CI_Date>
</gmd:date>
</gmd:CI_Citation>
</gmd:specification>
<gmd:explanation gco:nilReason="missing">
</gmd:explanation>
<gmd:pass>
<gco:Boolean>undefined</gco:Boolean>
</gmd:pass>
</gmd:DQ_ConformanceResult>
</gmd:result>
</gmd:DQ_DomainConsistency>
</gmd:report>
<gmd:lineage>
<gmd:LI_Lineage>
<gmd:statement>
<gco:CharacterString>La información base con la cual fue
elaborado este conjunto de datos proviene de las siguientes entidades:
Departamento Administrativo Nacional de Estadística (DANE), Enviromental
Systems Research Institute (ESRI), Instituto de Investigación de Recursos
Biológicos Alexander von Humboldt (IAVH), Instituto Geográfico Agustín
Codazzi (IGAC), National Imagery and Mapping Agency (NIMA), Releases
Enhanced Shuttle Land Elevation Data (SRTM), Unidad Administrativa Especial
del Sistema de Parques Nacionales Naturales (UAESPNN) Y United States
Geological Survey (USGS).</gco:CharacterString>
</gmd:statement>
</gmd:LI_Lineage>
</gmd:lineage>
</gmd:DQ_DataQuality>
</gmd:dataQualityInfo>
<gmd:metadataConstraints>
<gmd:useLimitation>
<gco:CharacterString>No existe limitaciones de acceso y uso para
el metadato.</gco:CharacterString>
</gmd:metadataConstraints>
<gmd:metadataMaintenance>
</gmd:metadataMaintenance>
</gmd:MD_Metadata>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Edit-metadata-languaje-spanish-tp5215628p5215751.html
