[GeoNetwork-users] Editing config files causes issues at re startup.sh [SEC=UNCLASSIFIED]
Hi Guys
Issue with restarting Geonetwork 3.4.2
If I edit the ../geonetwork/WEB-INF/config-db/jdbc.properties file
Then when GeoNetwork restarted I either get:
1) Blank screen - if done while tomcat running
2) Clean install from war file - if done while tomcat not-running
Either way I have to reinsert iso19115-3 schema_plugin
Any hints
I am currently running on the H2 database with default admin/password and instance name as:
I can't get GN to talk to Oracle 10g on a remote server
I don't have support for PostGIS in organisation
I don't have a convenient instance to use (and don't like MS SQL Server anyway)
e
[cid:image003.png@anonymised.com]
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences
Department of Agriculture and Water Resources
GPO Box 858 Canberra City ACT Australia 2601
44 Mort St Braddon ACT 2612
Ph: +61 (0)2 6272 5627
Email: Evert.Bleys@anonymised.com
IMPORTANT - This email and any attachments have been issued by the Australian Government Department of Agriculture and Water Resources. The material transmitted is for the use of the intended recipient only and may contain confidential, legally privileged, copyright or personal information. You should not copy, use or disclose it without authorisation from the Department. It is your responsibility to check any attachments for viruses and defects before opening or forwarding them.
If you are not an intended recipient, please contact the sender of this email at once by return email and then delete both messages. Unintended recipients must not copy, use, disclose, rely on or publish this email or attachments. The Department of Agriculture and Water Resources is not liable for any loss or damage resulting from unauthorised use or dissemination of, or any reliance on, this email or attachments.
If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one, advise the sender by return e-mail accordingly. This notice should not be deleted or altered
(attachments)
Hi Evert
There's a pull request to fix some issues related to Oracle:
https://github.com/geonetwork/core-geonetwork/pull/2777, should be
integrated for 3.4.3 release and hopefully solve this issue.
Have you check the log file? I guess should contain some errors in the
startup causing this, maybe you can provide it to check, otherwise is a bit
difficult to know what is the exact error.
Jose García
On Wed, May 23, 2018 at 6:06 AM, Bleys, Evert <
Evert.Bleys@anonymised.com> wrote:
Hi Guys
Any hints
instance name as:
anyway)
e
BLEYS Evert Mr
Data Manager
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
