Dear all,
I have Geonetwork and Geoserver being fired by Tomcat7 and I have created around 600 metadata using the instructions according to https://github.com/AstunTechnology/environmentagency_csv_import.
The metadata template, attached to this message works perfectly fine for geonetwork v2.10.3 and older versions. Now, I am using version 3.0.4 and I am facing three issues:
1 - I got to upload the same xml file in attached to the catalog, but I cannot edit it. When I click on edit tool, it does not show anything.
2 - I do not see any BaseMap for the Spatial Extent. I just see a yellow tile (polygon boundings) over a white background.
3 - I have a Geoserver WMS service ( http://localhost:6060/geoserver/msdi_chm/wms) to add the data to the map. When I click on add to map, it does not show the data.
Could someone give me any help me to figure out what is going wrong?
Thank you very much for your time in advance.
(attachments)
00c4abab-4014-40b3-af87-0011c0e14190.xml (29.2 KB)
