[GeoNetwork-users] Editor in Geonetwork 2.10
Hello,
I am using geonetwork 2.10.2.
Is Editor can edit his own metadata and same group of metadata?
For example Editor1 create one metadata called Data1.
Editor2 create one metadata called Data2.Both Editor1 and Editor2 are same
group.
My question is Editor1 can view and edit the metadata(Data2) of Editor2?
Please let me know. Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Editor-in-Geonetwork-2-10-tp5091604.html
Hi
If you enable the edit permissions in the group owner for the metadata then
any user in the group owner can edit it. If you remove the edit permissions
in the group owner, only the user that created it should be able to edit it.
For view permissions, I think should work similar.
Jose García
On Thu, Nov 28, 2013 at 8:40 AM, udhaya <udhay.forum@anonymised.com> wrote:
Hello,
group.
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don't have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics
Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349351&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/&gt; for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
Hello,
By default the all the privilege options are checked when published(insert)
the metadata record for specific group user through Geonetwork GUI.
I have attached and highlighted the privilege options in the snapshot.
Is the intent behaviour of Geonetwork?
Because I got two option(Publish and Notify) only checked When I
published(insert) the metadata record through Programatically using* Java*
*code.*
I am using Geonetwork 2.10
[image: Inline image 1]
Please let me know.Thanks
On Thu, Nov 28, 2013 at 5:15 PM, Jose Garcia [via OSGeo.org] <
ml-node+s1560n5091656h58@anonymised.com> wrote:
Hi
then
permissions
it.
Jose García
On Thu, Nov 28, 2013 at 8:40 AM, udhaya <[hidden email]<http://user/SendEmail.jtp?type=node&node=5091656&i=0&gt;&gt;
wrote:
> Hello,
same
> group.
your
AppDynamics
> Pro!
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5091656&i=1&gt;
Pro!
[hidden email] <http://user/SendEmail.jtp?type=node&node=5091656&i=2&gt;
If you reply to this email, your message will be added to the discussion
below:
http://osgeo-org.1560.x6.nabble.com/Editor-in-Geonetwork-2-10-tp5091604p5091656.html
To unsubscribe from Editor in Geonetwork 2.10, click here<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5091604&code=dWRoYXkuZm9ydW1AZ21haWwuY29tfDUwOTE2MDR8NzI4MDM1Mjcx&gt;
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html!nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers!nabble%3Aemail.naml-instant_emails!nabble%3Aemail.naml-send_instant_email!nabble%3Aemail.naml&gt;
Privilege.PNG (25K) <http://osgeo-org.1560.x6.nabble.com/attachment/5091683/0/Privilege.PNG&gt;
View this message in context: http://osgeo-org.1560.x6.nabble.com/Editor-in-Geonetwork-2-10-tp5091604p5091683.html
