Hi List,
I've been having problems with the metadata editor. Sometimes when I try to
edit/create a new metadata record, the editor won't completely load. It
will load the boxes on the right side for the associated resources,
validation, and suggestions, but that's it. If it does it load after
waiting for a little bit, I have problems linking resources to the metadata
record. I get an error saying "Current URL could not be retrieved by the
catalog (may be an issue with the catalog proxy)" even though when I click
on the link, it works. Another thing that happens when I try to link
resources is that sometime after I clink on the "add link" button, it's
almost like it freezes because nothing else happens. I have to close the
window and start it back up again. I have tried rebooting the server and
that helped for about a day, but now I'm having the same problems again.
I'm running Geonetwork 3.1 if that helps.
Heather
Heather M. Lucier
Data Architect
University of Michigan
Cooperative Institute for Limnology and Ecosystems Research (CILER)
@ NOAA Great Lakes Environmental Research Laboratory (GLERL)
4840 South State Road | Ann Arbor, MI 48108
734-741-2290 | hlucier@anonymised.com
Did you check the logs ?
The md.edit service should return an error if not loading.
On Mon, May 1, 2017 at 9:14 PM, Heather Lucier <hlucier@anonymised.com> wrote:
Hi List,
Heather
Heather M. Lucier
Data Architect
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
