[GeoNetwork-users] eml-gbif
Hi Carlos,
2014-11-12 17:40 GMT+01:00 Carlos Andres Beltran <cbeltran@anonymised.com>:
Hi François Prunayre
I clone the repository https://github.com/geonetwork/schema-plugins and
copy the folder eml-gbif in my GeoNetwork instalation
geonetwork/WEB-INF/data/config/schema_plugins.
tomcat restart, access to my geonetwork, select schemas (eml-gbif) later
add template and add example metadata, all good over here.
Now add new metadata, but in the window not appears to select eml-gibf.
Can you help me?.
I did not work on this schema plugin for GBIF, so I CC your question to the
list in case others can help ?
BTW, there is only samples
https://github.com/geonetwork/schema-plugins/tree/develop/eml-gbif/src/main/plugin/eml-gbif/sample-data
(and no templates) in this schema so at least you should have records once
samples are loaded and create new records from them ?
Cheers.
Francois
Thanks
