Hi, Kevin. Thank you for the answer. I tried your solution but it is still
not working for me.
Actually I formated my PC but I still get stuck in the same issue, so I
think I am doing something wrong on the installation process.
I installed Tomcat using this tutorial:
https://www.digitalocean.com/community/tutorials/how-to-install-apache-tomcat-8-on-ubuntu-16-04
Then I deployed GN 3.2.1 from the .war file in the webapps folder. The
deploy goes OK, but when I try to start the application I get this message:
FAIL - Application at context path /geonetwork could not be started
The complete logs in catalina.out file is this:
13-Mar-2017 11:42:52.652 INFORMAÇÕES [http-nio-8080-exec-10]
org.apache.catalina.core.ApplicationContext.log No Spring
WebApplicationInitializer types detected on classpath
log4j:ERROR setFile(null,true) call failed.
java.io.FileNotFoundException: logs/geonetwork.log (Arquivo ou diretório
não encontrado)
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(FileOutputStream.java:270)
at java.io.FileOutputStream.<init>(FileOutputStream.java:213)
at java.io.FileOutputStream.<init>(FileOutputStream.java:133)
at org.apache.log4j.FileAppender.setFile(FileAppender.java:294)
at
org.apache.log4j.RollingFileAppender.setFile(RollingFileAppender.java:207)
at org.apache.log4j.FileAppender.activateOptions(FileAppender.java:165)
at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:307)
at
org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.java:295)
at
org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurator.java:176)
at
org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfigurator.java:191)
at
org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOMConfigurator.java:523)
at
org.apache.log4j.xml.DOMConfigurator.parseCategory(DOMConfigurator.java:436)
at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:1004)
at
org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:872)
at
org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:778)
at
org.apache.log4j.helpers.OptionConverter.selectAndConfigure(OptionConverter.java:526)
at org.apache.log4j.LogManager.<clinit>(LogManager.java:127)
at org.slf4j.impl.Log4jLoggerFactory.getLogger(Log4jLoggerFactory.java:66)
at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:270)
at
org.apache.commons.logging.impl.SLF4JLogFactory.getInstance(SLF4JLogFactory.java:156)
at
org.apache.commons.logging.impl.SLF4JLogFactory.getInstance(SLF4JLogFactory.java:132)
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java:274)
at
org.apache.jcs.utils.servlet.JCSServletContextListener.<clinit>(JCSServletContextListener.java:48)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at java.lang.Class.newInstance(Class.java:442)
at
org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:119)
at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4649)
at
org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5189)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at
org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1307)
at
org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:669)
at
org.apache.catalina.manager.HTMLManagerServlet.doPost(HTMLManagerServlet.java:217)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165)
at
org.apache.catalina.filters.CsrfPreventionFilter.doFilter(CsrfPreventionFilter.java:136)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192)
at
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at
at
at
org.apache.catalina.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:591)
at
org.apache.catalina.valves.RequestFilterValve.process(RequestFilterValve.java:319)
at
org.apache.catalina.valves.RemoteAddrValve.invoke(RemoteAddrValve.java:88)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at
org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:624)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:349)
at
org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:783)
at
org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at
org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:798)
at
org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1434)
at
org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
2017-03-13 11:42:54,397 WARN
[jeeves.config.springutil.JeevesApplicationContext] - Exception
encountered during context initialization - cancelling refresh attempt:
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'org.apache.activemq.xbean.XBeanBrokerService#0': Invocation
of init method failed; nested exception is java.io.IOException: Failed to
bind to server socket: tcp://localhost:61616 due to:
java.net.BindException: Endereço já em uso (Bind failed)
at
org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessBeforeInitialization(InitDestroyAnnotationBeanPostProcessor.java:136)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:408)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1570)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:772)
at
org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:839)
at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:538)
at
jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:97)
at
org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4727)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: java.io.IOException: Failed to bind to server socket:
tcp://localhost:61616 due to: java.net.BindException: Endereço já em uso
(Bind failed)
at
org.apache.activemq.util.IOExceptionSupport.create(IOExceptionSupport.java:33)
at
org.apache.activemq.transport.tcp.TcpTransportServer.bind(TcpTransportServer.java:138)
at
org.apache.activemq.transport.tcp.TcpTransportFactory.doBind(TcpTransportFactory.java:60)
at
org.apache.activemq.transport.TransportFactory.bind(TransportFactory.java:131)
at
org.apache.activemq.broker.TransportConnector.createTransportServer(TransportConnector.java:329)
at
org.apache.activemq.broker.TransportConnector.getServer(TransportConnector.java:155)
at
org.apache.activemq.broker.TransportConnector.start(TransportConnector.java:220)
at
org.apache.activemq.broker.BrokerService.startTransportConnector(BrokerService.java:2330)
at
org.apache.activemq.broker.BrokerService.startAllConnectors(BrokerService.java:2243)
at org.apache.activemq.broker.BrokerService.start(BrokerService.java:551)
at
org.apache.activemq.broker.BrokerService.autoStart(BrokerService.java:494)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at
org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleElement.invoke(InitDestroyAnnotationBeanPostProcessor.java:354)
at
org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor$LifecycleMetadata.invokeInitMethods(InitDestroyAnnotationBeanPostProcessor.java:305)
at
org.springframework.beans.factory.annotation.InitDestroyAnnotationBeanPostProcessor.postProcessBeforeInitialization(InitDestroyAnnotationBeanPostProcessor.java:133)
... 50 more
Caused by: java.net.BindException: Endereço já em uso (Bind failed)
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:387)
at java.net.ServerSocket.bind(ServerSocket.java:375)
at java.net.ServerSocket.<init>(ServerSocket.java:237)
at
javax.net.DefaultServerSocketFactory.createServerSocket(ServerSocketFactory.java:231)
at
org.apache.activemq.transport.tcp.TcpTransportServer.bind(TcpTransportServer.java:134)
... 66 more
2017-03-13 11:42:54,415 FATAL [jeeves.engine] - Raised exception during
init
2017-03-13 11:42:54,415 FATAL [jeeves.engine] - Exception :
2017-03-13 11:42:54,415 FATAL [jeeves.engine] - Message : Error
creating bean with name 'org.apache.activemq.xbean.XBeanBrokerService#0':
Invocation of init method failed; nested exception is java.io.IOException:
Failed to bind to server socket: tcp://localhost:61616 due to:
2017-03-13 11:42:54,417 FATAL [jeeves.engine] - Stack :
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
(Bind failed)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 50 more
at
at
... 66 more
13-Mar-2017 11:42:54.418 GRAVE [http-nio-8080-exec-10]
org.apache.catalina.core.StandardContext.listenerStart Exception sending
context initialized event to listener instance of class
java.lang.RuntimeException: Exception raised
at jeeves.server.JeevesEngine.handleStartupError(JeevesEngine.java:125)
at
jeeves.config.springutil.JeevesContextLoaderListener.contextInitialized(JeevesContextLoaderListener.java:145)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.springframework.beans.factory.BeanCreationException: Error
at
at
at
at
at
at
at
at
at
at
at
at
at
... 38 more
(Bind failed)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 50 more
at
at
... 66 more
13-Mar-2017 11:42:54.419 GRAVE [http-nio-8080-exec-10]
org.apache.catalina.core.StandardContext.startInternal One or more
listeners failed to start. Full details will be found in the appropriate
container log file
13-Mar-2017 11:42:54.420 GRAVE [http-nio-8080-exec-10]
org.apache.catalina.core.StandardContext.startInternal Context
[/geonetwork] startup failed due to previous errors
13-Mar-2017 11:42:54.637 GRAVE [http-nio-8080-exec-10]
org.apache.catalina.core.StandardContext.listenerStop Exception sending
context destroyed event to listener instance of class
java.lang.NullPointerException
at
jeeves.config.springutil.JeevesContextLoaderListener.contextDestroyed(JeevesContextLoaderListener.java:161)
at
org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4774)
at
org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5411)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:226)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
13-Mar-2017 11:42:54.640 ADVERTÊNCIA [http-nio-8080-exec-10]
org.apache.catalina.loader.WebappClassLoaderBase.clearReferencesThreads The
web application [geonetwork] appears to have started a thread named
[ElementEventQueue.QProcessor-1] but has failed to stop it. This is very
likely to create a memory leak. Stack trace of thread:
java.lang.Object.wait(Native Method)
java.lang.Object.wait(Object.java:502)
org.apache.jcs.engine.control.event.ElementEventQueue.take(ElementEventQueue.java:181)
org.apache.jcs.engine.control.event.ElementEventQueue.access$300(ElementEventQueue.java:35)
org.apache.jcs.engine.control.event.ElementEventQueue$QProcessor.run(ElementEventQueue.java:245)
Does anybody have any idea of what I am doing wrong?? Thank you!
2017-03-10 12:54 GMT-03:00 Durkee <kevin_durkee@anonymised.com>:
Hi Murilo
I'm on Windows so different OS, as well as tomcat 8 and I had the very same
issue last week.
For me the issue was with Java, I uninstalled then re-installed my JDK then
it worked properly.
Hope this helps
Kevin
View this message in context: http://osgeo-org.1560.x6.
nabble.com/Empty-pages-after-deleting-wro4j-cache-files-
tp5311664p5311771.html
Announcing the Oxford Dictionaries API! The API offers world-renowned
dictionary content that is easy and intuitive to access. Sign up for an
account today to start using our lexical data to power your apps and
projects. Get started today and enter our developer competition.
http://sdm.link/oxford
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
