Hey all,
I am trying to set up a GN-Server with all INSPIRE options turned on but I got 2 problems meanwhile!
The GN Version is 2.6.3!
SCHEMATRON VALIDATION FOR INSPIRE:
Could someone describe step by step how to enable the Schematron validation for INSPIRE.
Frankly speaking I have no idea how it should be done.
I read the report "INSPIRE support in GeoNetwork opensource" but for the 2.6.x series it just says
"manually copy INSPIRE Schematron from source or to run 'ant inspire' in the Schematrons directory".
I found the file <CATALINA BASE>/webapps/geonetwork/xml/schemas/iso19139/process/inspire-add-conformity.xsl.
Is this the correct file to add the INSPIRE schematron validation?
And how can I activate it? I have actually no idea what "run 'ant inspire'" should mean!?
TEMPORAL REFERENCE INDEXING
The document "INSPIRE support in GeoNetwork opensource" describes how to include date of publication, revision
or creation date in the LUCENE index.
It says that parameter "useDateAsTemporalExtend" in file <CATALINA BASE>/webapps/geonetwork/xml/schemas/iso19139/index-fields.xml
has to be set to true.
The section in the file looks as follows:
<xsl:param name="inspire">false</xsl:param>
<!-- If identification creation, publication and revision date
should be indexed as a temporal extent information (eg. in INSPIRE
metadata implementing rules, those elements are defined as part
of the description of the temporal extent). -->
<xsl:variable name="useDateAsTemporalExtent" select="false()"/>
Would this be the right configuration?
<xsl:param name="inspire">true</xsl:param>
<xsl:variable name="useDateAsTemporalExtent" select="true()"/>
Thanks for any help!
Till
Johann Heinrich von Thünen-Institut
Bundesforschungsinstitut für Ländliche Räume, Wald und Fischerei
- Institut für Waldökologie und Waldinventuren Eberswalde -
Alfred-Möller-Straße 1
16225 Eberswalde
Deutschland
Telefon/Mailbox: +49 (0)3334 65-310
E-Mail: till.kirchner@anonymised.com
