[GeoNetwork-users] enquire on installation on 64 bit server
hi, i want to install Geonetwork on the server, which is windows 2003 64 bit. Because there is some important data on the server, i can not do it roughly. Can i do it?
i am looking forward to your answer.Thank you in advance
Ling
_________________________________________________________________
ÉÏWindows Live ÖйúÊ×Ò³£¬ÏÂÔØMessenger2009°²È«°æ£¡
http://www.windowslive.cn
Dear Ling,
you should be able to install geonetwork without problems.
Since geonetwork is developed in java and this being a platform
independent language, it does not matter on which virtual machine you
execute the code.
Also, there are 32 and 64bit JREs for windows 64, since 64bit CPUs can
also execute the old 32bit instructions.
Unless geonetwork uses libraries making use of JNI, which is not the
case AFAIK, there should thus be no issues.
It is always advisable though to make a backup before doing an update.
good luck
Timo
Ling
上Windows Live 中国首页,下载Messenger2009安全版!
The Planet: dedicated and managed hosting, cloud storage, colocation
Stay online with enterprise data centers and the best network in the business
Choose flexible plans and management services without long-term contracts
Personal 24x7 support from experience hosting pros just a phone call away.
http://p.sf.net/sfu/theplanet-com
GeoNetwork-users mailing list
