[GeoNetwork-users] Error al instalar geonetwork
  Hola, al tratar de instalar el geonetwork, me ha salido este error, por
favor, me podrian decir cual es el problema y como puedo solucionarlo??
[localhost]# java -jar geonetwork-install-2.2.0.jar
Exception in thread "main" java.lang.ExceptionInInitializerError at
com.birosoft.liquid.LiquidLookAndFeel.loadIconImmediately(LiquidLookAndFeel.java:903)
at
com.birosoft.liquid.LiquidLookAndFeel.loadIcon(LiquidLookAndFeel.java:881)
at
com.birosoft.liquid.LiquidLookAndFeel.initComponentDefaults(LiquidLookAndFeel.java:685)
at
javax.swing.plaf.basic.BasicLookAndFeel.getDefaults(BasicLookAndFeel.java:130)
at javax.swing.UIManager.setLookAndFeel(UIManager.java:541)
at javax.swing.UIManager.setLookAndFeel(UIManager.java:585)
at
com.izforge.izpack.installer.GUIInstaller.loadLookAndFeel(GUIInstaller.java:389)
at
com.izforge.izpack.installer.GUIInstaller.<init>(GUIInstaller.java:118)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513) at
java.lang.Class.newInstance0(Class.java:355)
at java.lang.Class.newInstance(Class.java:308)
at com.izforge.izpack.installer.Installer.main(Installer.java:62) Caused by:
java.awt.HeadlessException: No X11 DISPLAY variable was set, but this
program performed an operation which requires it.
at
sun.java2d.HeadlessGraphicsEnvironment.getDefaultScreenDevice(HeadlessGraphicsEnvironment.java:64)
at
com.birosoft.liquid.skin.SkinImageCache.<clinit>(SkinImageCache.java:41)
... 15 more
Saludos,
Melina Pérez Pelayo
Weird!
Which version of java did you use?
Can you check your java version performing a java -version command.
Mathieu
On Fri, Jun 12, 2009 at 5:38 PM, Melina Perez <melinaorama@anonymised.com> wrote:
at
at
at
at
at
com.izforge.izpack.installer.GUIInstaller.&lt;init&gt;(GUIInstaller.java:118)
at
at
by:
at
at
com.birosoft.liquid.skin.SkinImageCache.&lt;clinit&gt;(SkinImageCache.java:41)
... 15 more
Saludos,
Melina Pérez Pelayo
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
GeoNetwork-users mailing list
Tengo instalado el jdk-6u13-linux-i586.bin que incluye el JRE y el
apache-tomcat-6.0.20.
at
at
at
at
at
at
at
by: java.awt.HeadlessException: No X11 DISPLAY variable was set, but this
at
at
... 15 more
Saludos,
Melina Pérez Pelayo
Melina Pérez Pelayo
Hi Melina,
look at the exception, it says:
"No X11 DISPLAY"
If you are using ssh to login, try "ssh -X yourhostname", X-forwarding
must be enabled at the server side, too.
If you are working on a local machine and you did "su" to become root,
you could try sudo: as a user you do "sudo java -jar ...". You have to
use the password of the user then, not the root password. And the user
needs to be in the sudoers file.
Good luck!
ck
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 15 more
> Saludos,
> Melina Pérez Pelayo
