I seemed to have corrected most of my problems with Geonetwork 2.1,
Tomcat 5.5 and Java 1.6 on Ubuntu. I am using Java 1.6 but have done
testing on 1.5 and do not notice any differences at the moment.
The system is running, although intermap is still not 100% functional
at the moment. The tmp directory of Intermap was not properly configured
on my system, which was causing my problem. On Ubuntu, I changed the
/webapps/intermap/WEB-INF/config.xml to the following
<!-- temp files -->
<param name="tempDir"
value="/usr/share/tomcat5.5/webapps/intermap/tmp/" />
<param name="tempDeleteMinutes" value="15" />
<param name="tempUrl" value="/intermap/tmp" />
<!-- http cache -->
<param name="httpCacheDir"
value="/usr/share/tomcat5.5/webapps/intermap/httpCache/" />
<param name="httpCacheDeleteEvery" value="60" />
<param name="useCache" value="true" />
where the tempDir and httpCacheDir are absolute paths.
After this change, Intermap seems to work pretty much OK, except the
initial map disappears after a few seconds. However, I can add layers
from various WMS servers, and things seem to work fine. Once I diagnose
my other problems, I will send them to the list.
Best regards,
Jason
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On Behalf Of
Pickering, Jason
Sent: 26 September 2007 09:16
To: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Error installing GN 2.1
Hi Jeroen,
For various reasons, we have to use Java 1.6 on our production server
for Geonetwork. Are the issues documented someplace? Geonetwork appears
to work fine with Java 1.6, Tomcat 5.5 on Ubuntu for me, but I am not
sure if there are other problems lurking. Is your recommendation NOT to
run Geonetwork with Java version 1.6? Intermap does not appear to want
to work properly at all with version 1.6 at all.
Jaso
n
Jeroen Ticheler
Sent: 25 September 2007 00:30
To: Stephen Waswa
Cc: geonetwork-users@lists.sourceforge.net
Hi Waswa,
GeoNetwork is supposed to work with Java version 1.5. I know some
have been able to run it on 1.6 but there are still issues that cause
this not to work on all systems. The Windows installer checks for a
valid version of Java and hopefully pointed you to the download page
at Sun to get that version. The Windows version with JRE has the
correct version embedded. That one should run the installation also
with the version 1.4 to 1.6, and will use version 1.5 when running
the GeoNetwork application.
Hope that helps,
Ciao,
Jeroen
On Sep 24, 2007, at 3:06 PM, Stephen Waswa wrote:
Jeroen
Congratulations for the new release
I have downloaded and tried installing the "geonetwork-install-2.1.0
(2)" but
am getting an error that "Cannot find Java 1.5.0 - 1.5.0_12", I
already have
installed jdk1.6.0_01 and set the environment variables correctly
as I have
been using it, what might I have done wrong? Or isn't jdk1.6
supported?
Kind Regards
Waswa Steve
The ability to discipline yourself to delay gratification in the
short term
in order to enjoy greater rewards in the long term is the
indispensable
prerequisite for success............Tracy Brian
Stephen B. Waswa
IT Consultant
Somalia Water and Land Information Management System,
Food and Agriculture Organization of the United Nations,
P.O. Box 30470 -00100 Nairobi (Kenya)
Office:
3rd Floor Kalson Tower, Crescent Road,
Parklands, Nairobi
Tel: + 254 20 3743464
Fax: +254 20 3743498
Cellphone +254 721826320
e-mail: <mailto:swaswa@anonymised.com> swaswa@anonymised.com
<http://www.faoswalim.org/> www.faoswalim.org
The information contained in this e-mail is intended for the person
to whom
it is addressed and may contain confidential and/or privileged
information,
which might not reflect the official position of the Food and
Agriculture
Organization of the United Nations. If you have received this e-
mail in
error, please immediately notify swaswa@anonymised.com and delete this
message from your system and server. You may not copy, retain,
forward or
disclose its contents to anyone else or take any action based upon
it, if is
not addressed to you personally.
Defy all challenges. Microsoft(R) Visual Studio 2005.
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
