Hello list,
when I press “Interactive Maps” button in search results for a web map service stored on a local server for some services a NullPointerExeption occurs. For others this works fine. All these services are stored on the same folder and metadata entries look quiet similar.
However when I try to load them via “Add a new layer” button directly in Intermap it works for all services… (I’m using GN 2.2)
Here are some information from the /jetty/log/intermap.log
2010-08-17 14:34:37,306 INFO [jeeves.request] - ==========================================================
2010-08-17 14:34:37,306 INFO [jeeves.request] - HTML Request (from 141.65.4.192) : /intermap/srv/en/map.addServices.embedded
2010-08-17 14:34:37,306 DEBUG [jeeves.request] - Method : GET
2010-08-17 14:34:37,306 DEBUG [jeeves.request] - Content type : null
2010-08-17 14:34:37,306 DEBUG [jeeves.request] - Accept : text/javascript, text/html, application/xml, text/xml, /
2010-08-17 14:34:37,306 INFO [jeeves.service] - Dispatching : map.addServices.embedded
2010-08-17 14:34:37,306 DEBUG [jeeves.service] - → parameters are :
false
Flood risk zones
2
http://141.65.7.61/cgi-bin/mapserv?map=/var/www/map/RM_FloodRiskZonesWGS84.map
2010-08-17 14:34:37,306 ERROR [jeeves.service] - Exception when executing service
2010-08-17 14:34:37,306 ERROR [jeeves.service] - (C) Exc : java.lang.NullPointerException
2010-08-17 14:34:37,306 DEBUG [jeeves.service] - Raised exception while executing service
en
2010-08-17 14:34:37,306 INFO [jeeves.service] - → dispatching to error for : map.addServices.embedded
2010-08-17 14:34:37,308 INFO [jeeves.service] - → transforming with stylesheet : /usr/local/geonetwork22/web/intermap/xsl/copy_error.xsl
2010-08-17 14:34:37,311 INFO [jeeves.service] - → end error transformation for : map.addServices.embedded
2010-08-17 14:34:37,311 INFO [jeeves.service] - → error ended for : map.addServices.embedded
Do you have any suggestions what is not working for this layer (WMS)?
Best regards,
Christian
Christian Gadge
Department Stadt- und Umweltsoziologie
Helmholtz-Zentrum für Umweltforschung GmbH - UFZ
Permoserstraße 15 / 04318 Leipzig / Germany
Telefon +49 341 235 1730 / Fax +49 341 235 1834
[christian.gadge@anonymised.com](mailto:christian.gadge@anonymised.com) / [www.ufz.de](http://www.ufz.de)
Sitz der Gesellschaft: Leipzig
Registergericht: Amtsgericht Leipzig, Handelsregister Nr. B 4703
Vorsitzender des Aufsichtsrats: MinR Wilfried Kraus
Wissenschaftlicher Geschäftsführer: Prof. Dr. Georg Teutsch
Administrativer Geschäftsführer: Dr. Andreas Schmidt
