Hallo,
I'm using Geonetwork 2.4.2 and Tomcat 6 on Vista. When I tried to delete the sample records in GN, it gave me error: shp has extra record. I don't know if this is somehow related, but this error occurred after adding CSW harvesting node. I tried disabling the node then deleting the records again to no avail. Also, when I tried to re-setup the McKoi db, it gave me "<no message>" error when I click the import sample data button. Has anyone experienced the same case? Any hint?
Thank you.
