[GeoNetwork-users] Error trying to setup PostGIS database through GAST
I'm in the process of switching our GN installation from MySQL to
Postgre/PostGIS, in order to take advantage of spatial index.
I have already installed PostgreSQL and PostGIS, and created user and
database:
But when I try to actually set up the database through GAST, I get:
<http://osgeo-org.1560.n6.nabble.com/file/n5008114/GAST_error.png&gt;
Even though my config seems correct:
<http://osgeo-org.1560.n6.nabble.com/file/n5008114/GAST_config.png&gt;
Any thoughts on the matter?
Thank you,
André.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-trying-to-setup-PostGIS-database-through-GAST-tp5008114.html
PostgreSQL log:
LOG: could not connect to Ident server at address "127.0.0.1", port 113:
Connection refused
FATAL: Ident authentication failed for user "geonetwork"
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-trying-to-setup-PostGIS-database-through-GAST-tp5008114p5008131.html
Solved changing the user authentication method in pg_hba.conf.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-trying-to-setup-PostGIS-database-through-GAST-tp5008114p5008782.html
