[GeoNetwork-users] Error using gast in 2.4
Hello folks,
I am trying to install GN 2.4 on a remote Ubuntu Server so no GUI :slight_smile:
I recive this error running
java -jar gast.jar -setupdb
2009-06-25 22:46:24,684 DEBUG [gast] - - Filling table : IsoLanguagesDes
java.lang.StringIndexOutOfBoundsException: String index out of range: 41
  at java.lang.String.substring(String.java:1935)
  at org.fao.gast.lib.druid.Codec.decodeString(Codec.java:44)
  at org.fao.gast.lib.druid.ImportHandler.handleRow(Import.java:118)
  at org.fao.gast.lib.druid.DdfLoader.handleRow(DdfLoader.java:117)
  at org.fao.gast.lib.druid.DdfLoader.load(DdfLoader.java:80)
  at org.fao.gast.lib.druid.Import.load(Import.java:34)
  at org.fao.gast.lib.DatabaseLib.fillTables(DatabaseLib.java:456)
  at org.fao.gast.lib.DatabaseLib.fillTables(DatabaseLib.java:428)
  at org.fao.gast.lib.DatabaseLib.setup(DatabaseLib.java:109)
  at org.fao.gast.cli.createdb.CreateDB.exec(CreateDB.java:39)
  at org.fao.gast.cli.Cli.start(Cli.java:59)
  at org.fao.gast.boot.Util.boot(Util.java:136)
  at org.fao.gast.Gast.main(Gast.java:50)
Exception in thread "main" java.awt.HeadlessException:
No X11 DISPLAY variable was set, but this program performed an operation
which requires it.
  at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:159)
  at java.awt.Window.<init>(Window.java:414)
  at java.awt.Frame.<init>(Frame.java:403)
  at java.awt.Frame.<init>(Frame.java:368)
  at
javax.swing.SwingUtilities$SharedOwnerFrame.<init>(SwingUtilities.java:1731)
  at javax.swing.SwingUtilities.getSharedOwnerFrame(SwingUtilities.java:1808)
  at javax.swing.JOptionPane.getRootFrame(JOptionPane.java:1673)
  at javax.swing.JOptionPane.showOptionDialog(JOptionPane.java:846)
  at javax.swing.JOptionPane.showMessageDialog(JOptionPane.java:650)
  at javax.swing.JOptionPane.showMessageDialog(JOptionPane.java:621)
  at org.fao.gast.boot.Util.showError(Util.java:166)
  at org.fao.gast.boot.Util.boot(Util.java:141)
The installation works, but there are no categories in the left menu and
the admin login doesn't work.
On the same machine the 2.2 installation is ok.
Thanks
Luca
ME Luca Casagrande
Open Source GIS analyst and developer
Gfosservices SA
http://www.gfosservices.com
skype: lucacasagrande
email: luca.casagrande[at]gmail.com
