Hello,
After installing GeoNetwork, I tried to access the main page, however Jetty returns the following error:
Error 404 - Not Found.
No context on this server matched or handled this request.
Contexts known to this server are:
* /geonetwork <http://localhost:8080/geonetwork> ---> o.e.j.w.WebAppContext@anonymised.com{geonetwork,/geonetwork,[file:///C:/randd/geonetwork/web/geonetwork/, jar:file:///C:/randd/geonetwork/web/geonetwork/WEB-INF/lib/handlebars-3.0.3.jar!/META-INF/resources, jar:file:///C:/randd/geonetwork/web/geonetwork/WEB-INF/lib/jquery-1.10.2-1.jar!/META-INF/resources, jar:file:///C:/randd/geonetwork/web/geonetwork/WEB-INF/lib/less-1.3.3.jar!/META-INF/resources, jar:file:///C:/randd/geonetwork/web/geonetwork/WEB-INF/lib/coffee-script-1.10.0.jar!/META-INF/resources, jar:file:///C:/randd/geonetwork/web/geonetwork/WEB-INF/lib/json2-20110223.jar!/META-INF/resources, jar:file:///C:/randd/geonetwork/web/geonetwork/WEB-INF/lib/validate.js-0.8.0.jar!/META-INF/resources, jar:file:///C:/randd/geonetwork/web/geonetwork/WEB-INF/lib/jslint-20140708-394bf29.jar!/META-INF/resources, jar:file:///C:/randd/geonetwork/web/geonetwork/WEB-INF/lib/emberjs-1.9.0-1.jar!/META-INF/resources, jar:file:///C:/randd/geonetwork/web/geonetwork/WEB-INF/lib/envjs-1.2.jar!/META-INF/resources, jar:file:///C:/randd/geonetwork/web/geonetwork/WEB-INF/lib/jshint-2.6.3-2.jar!/META-INF/resources],UNAVAILABLE}{C:\randd\geonetwork\web\geonetwork}
Thank you,
Best regards.
Lyes
From: Juan Luis Rodríguez Ponce <juanluisrp@anonymised.com>
Sent: Tuesday, March 3, 2020 7:55 PM
To: Lyes Mokraoui <lyes.mokraoui@anonymised.com>
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Installer hanging on Windows 10
I don't know what could be happening. I installed a Windows 10 VM image from Microsoft web [1]. Then I've downloaded and installed OpenJDK 8 from AdoptOpenJDK webpage [2]. Finally I've downloaded geonetwork-install-3.10.1-0.jar from SourceForge and I double clicked it. The installer has started and after selecting a target directory where I have write permissions the installer has finished more or less successfully. Last page of the installer is empty as you show in your screenshot, but it has finished and you can click Quit or kill the installer if it doesn't finish. The only thing missing are the shortcut creation step.
If you go to the installation directory, then bin and run startup.bat script GeoNetwork should start and you should be able to access it at http://localhost:8080/geonetwork
[1] https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/
[2] https://adoptopenjdk.net/releases.html
On Tue, Mar 3, 2020 at 10:50 AM Lyes Mokraoui <lyes.mokraoui@anonymised.com <mailto:lyes.mokraoui@anonymised.com> > wrote:
Dear All,
I decided to go ahead and install GeoNetwork on my notebook. I downloaded
the latest Jar installer, however the installer seams to run in an infinite
loop after unpacking the files.
Is there anything I should do before installing? UAC is off and I do not
have any anti-virus on when installing the software.
Juan Luis.
Vriendelijke groeten / Kind regards,
Juan Luis Rodríguez.
<http://www.geocat.net/>
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: <tel:+31318416664> +31 (0)318 416664
Please consider the environment before printing this email.
