[GeoNetwork-users] Error while adding layers on geonetwork viewer
Hi Hakan
I had the same error:
This fails to add anything to the map:
  Search result > Layers (globe icon) > Add 2 layers to map
But I can add WMS to map manually by:
  Map > Add a layer > WMS > type a WMS service URL
I think for this to work:
Either the Online Resource Name in the metadata record must match the layer
name in the WMS
Or the parent <layer> in the WMS capabilities needs to be a simple
displayable layer (not a group of nested layers)
If your Online Resource Name does match your WMS layer name, then maybe
your problem is to do with special characters in the layer name? Have you
tried changing the layer name?
Apologies if this message does not attach to the right thread. I found your
message on the web archives and subscribed today to reply.
Regards
Jonathan
From: Hakan ATAK <hakan.atak@anonymised.com> - 2015-12-08 12:31:50 > Hi, > I set
up geonetwork 3.02 and added Turkish language files. I created some
metadata and tried to add to map. I get this error on map viewer's layer
panel. > · Layer 'Kapı' not found in WMS capability<
http://cbssrv3:6080/arcgis/services/KAPI/MapServer/WMSServer?request=GetCapabilities&service=WMS&gt;;\.
The layer may not be displayed properly. > · Something went wrong while
loading tile'- no tile URL found- ...'<
http://cbsgeoportal4:8080/geonetwork/srv/eng/-%20no%20tile%20URL%20found-&gt;;
for layer 'Kapı'. > When i add WMS link to viewer it works but otherwise i
get the error " > How can i solve that problem? Thank you very much. > Best
Regards, > Hakan ATAK
