[GeoNetwork-users] error while installing geonetwork open source – i guess Mckoi related for turkish locale
first of all, sorry for cross referencing.
I am new and trying to install on win XP service pack 3 by using the
file "geonetwork-install-with-jre-2.2.0.exe", but getting error:
"RuntimeException SQL Error: Unrecognised operator type: ın"
I guess this error could be related with turkish character. we have
two different character for i with/without dot like "i" and "ı"
I completed the installation with this error. and then clicked "start
server". this time the error is: "SQL Error: Table
'SYS_INFO.sUSRPassword' was not found." after this error, starting
server in the command prompt window stops and nothing happens.
I do not know where to look for this error. I did some googling, but i
could not solve them. For database part, postgresql 8.3.5-1 and ms sql
server 2000 client is installed on this desktop. Is this second error
related with these databases? or naturally related with the first one?
i do not know very much java stuff but i am expert in gis, meaing i am
a new user for Mckoi side, and made some googling, then found your
reply: http://www.mckoi.com/database/maillist/msg04888.html
Is the error "RuntimeException SQL Error: Unrecognised operator type:
ın" related with turkish locale?
if yes:
the advice you explained in the e-mail does not work for me, or i am
doing someting wrong. what i did exactly as follows:
C:\Program Files\geonetwork\web\geonetwork\WEB-INF\lib>java
-Duser.language=en -Duser.region= -jar ./mckoidb.jar -create "admin"
"admin"
Mckoi SQL Database ( 1.0.3 )
Copyright (C) 2000 - 2004 Diehl and Associates, Inc. All rights reserved.
Use: -h for help.
  Mckoi SQL Database comes with ABSOLUTELY NO WARRANTY.
  This is free software, and you are welcome to redistribute it
  under certain conditions. See LICENSE.txt for details of the
  GPL License.
Error: configuration file './db.conf' was not found.
C:\Program Files\geonetwork\web\geonetwork\WEB-INF\lib>cd..
C:\Program Files\geonetwork\web\geonetwork\WEB-INF>cd db
C:\Program Files\geonetwork\web\geonetwork\WEB-INF\db>java
-Duser.language=en -Duser.region= -jar ../lib/mckoidb.jar -create
"admin" "admin"
Use: -h for help.
  GPL License.
[com.mckoi.debug.Debug - Exception thrown: 'Conglomerate already
exists: DefaultDatabase']
java.io.IOException: Conglomerate already exists: DefaultDatabase
        at com.mckoi.database.TableDataConglomerate.minimalCreate(TableDataConglomerate.java:1014)
        at com.mckoi.database.TableDataConglomerate.create(TableDataConglomerate.java:1055)
        at com.mckoi.database.Database.create(Database.java:1696)
        at com.mckoi.database.control.DBController.createDatabase(DBController.java:96)
        at com.mckoi.runtime.McKoiDBMain.doCreate(McKoiDBMain.java:114)
        at com.mckoi.runtime.McKoiDBMain.main(McKoiDBMain.java:287)
Exception in thread "main" java.lang.Error: IO Error: Conglomerate
        at com.mckoi.database.Database.create(Database.java:1752)
maybe the problem is related with only my paths, but i do not know how
to do or can not see.
Could you please tell me exact command according to the my path?
it seems strange to me that "-Duser.region=" is empty. Should I add
"tr" or someting else?
I also attached snapshot and the full details of these errors for your info.
fullErrorMsgAfterStartServer.txt
could you help me?
Volkan Kepoglu
(attachments)
fullErrorMsgAfterStartServer.txt (6.73 KB)
Did you try to use GAST to initialize your mckoi database first ?
I mean you could try to setup your default database with GAST instead of
accessing directly to mckoi jar file.
Have a look at the documentation [1], especially §13, page 78.
GAST is setting up default database for you and help you to configure your
geonetwork installation.
[1] http://geonetwork-opensource.org/documentation/manual/geonetwork-manual
HTH,
Mathieu
On Fri, Nov 28, 2008 at 12:05 PM, volkan kepoglu <vkepoglu@...54...> wrote:
if yes:
"admin"
Use: -h for help.
GPL License.
"admin" "admin"
Use: -h for help.
GPL License.
       at
       at
       at
       at
info.
could you help me?
Volkan Kepoglu
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
GeoNetwork-users mailing list
Mathieu Coudert
mcoudert@...54...
could not start GAST.
tried "Start GAST" from start menu or "java -jar gast/gast.jar". not
working.
giving the same error:
"java.lang.RuntimeException: SQL Error: Unrecognised operator type: ²n"
Mathieu Coudert-2 wrote:
[1]
HTH,
Mathieu
On Fri, Nov 28, 2008 at 12:05 PM, volkan kepoglu <vkepoglu@anonymised.com>
wrote:
if yes:
"admin"
reserved.
Use: -h for help.
GPL License.
"admin" "admin"
reserved.
Use: -h for help.
GPL License.
       at
       at
       at
       at
info.
could you help me?
Volkan Kepoglu
challenge
prizes
world
Mathieu Coudert
mcoudert@anonymised.com
challenge
prizes
world
View this message in context: http://www.nabble.com/error-while-installing-geonetwork-open-source-–-i-guess-Mckoi-related-for-turkish-locale-tp20734021p20746890.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
