[GeoNetwork-users] Error with geonetwork when stopping Tomcat
Dear all,
I have the following issue with :
geonetwork 2.1
Tomcat/5.5.26
JAVA 1.5.0_10
when I stop tomcat some null pointer exception are raising in the catalina.out
  Java.lang.reflect.InvocationTargetException
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
Caused by: java.lang.NullPointerException
  at org.apache.log4j.LogManager.getLogger(LogManager.java:188)
  at org.apache.log4j.Category.getInstance(Category.java:519)
  at com.k_int.util.LoggingFacade.Log4JCategory.<init>(Unknown Source)
The problem occurs when I try to stop Tomcat. Tomcat then seems to be stopped (pages are no longer reachable), but the Tomcat process is still active in the UNIX process queue.
Therefore, when I start Tomcat again, two processes are available which interfere each other.
Furthermore, the reason why I would like to stop Tomcat is to release its database connection, and if the process is still active, the database connection is not deleted.
When i drop the geonetwork application from tomcat I didn't have this issue.
How to solve this problem ?
Any ideas ?
Thank you by advance.
Fabien Bachraty.
View this message in context: http://n2.nabble.com/Error-with-geonetwork-when-stopping-Tomcat-tp2615179p2615179.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Hi Fabien,
Do you have this parameter in your startup script: -Djava.awt.headless=true
I had similar problems in the past that caused the shutdown process to fail in relation to InterMap.
Ciao,
Jeroen
On Apr 10, 2009, at 10:09 AM, FBachraty wrote:
Dear all,
geonetwork 2.1
Tomcat/5.5.26
JAVA 1.5.0_10
Any ideas ?
Fabien Bachraty.
This SF.net email is sponsored by:
High Quality Requirements in a Collaborative Environment.
Download a free trial of Rational Requirements Composer Now!
Best Open Source Mac Front-Ends 2024
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Thank you Jeroen,
But unfortunately it does'nt change anything
I put :
export CATALINA_OPTS="-Djava.awt.headless=true"
on catalina.sh
I stop tomcat and all old process, and then I restart it
Is that correct ?
When I stop it I still have the same issues.
Anyway thank you for this good idea.
In addition I write here the complete error message.
2009-04-10 13:26:33,031 INFO [jeeves.engine] - === System stopped ========================================
java.lang.reflect.InvocationTargetException
  at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
  at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
  at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
  at com.k_int.util.LoggingFacade.LogContextFactory.getContext(Unknown Source)
  at com.k_int.hss.HSSSearchTask.<clinit>(HSSSearchTask.java:53)
  at sun.misc.Unsafe.ensureClassInitialized(Native Method)
  at sun.reflect.UnsafeFieldAccessorFactory.newFieldAccessor(UnsafeFieldAccessorFactory.java:25)
  at sun.reflect.ReflectionFactory.newFieldAccessor(ReflectionFactory.java:122)
  at java.lang.reflect.Field.acquireFieldAccessor(Field.java:917)
  at java.lang.reflect.Field.getFieldAccessor(Field.java:898)
  at java.lang.reflect.Field.set(Field.java:656)
  at org.apache.catalina.loader.WebappClassLoader.clearReferences(WebappClassLoader.java:1620)
  at org.apache.catalina.loader.WebappClassLoader.stop(WebappClassLoader.java:1500)
  at org.apache.catalina.loader.WebappLoader.stop(WebappLoader.java:734)
  at org.apache.catalina.core.StandardContext.stop(StandardContext.java:4398)
  at org.apache.catalina.core.ContainerBase.stop(ContainerBase.java:1067)
  at org.apache.catalina.core.StandardEngine.stop(StandardEngine.java:448)
  at org.apache.catalina.core.StandardService.stop(StandardService.java:510)
  at org.apache.catalina.core.StandardServer.stop(StandardServer.java:734)
  at org.apache.catalina.startup.Catalina.stop(Catalina.java:602)
  at org.apache.catalina.startup.Catalina.start(Catalina.java:577)
  at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:295)
  at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:433)
  ... 29 more
10 avr. 2009 13:26:33 org.apache.coyote.http11.Http11BaseProtocol destroy
INFO: Arrêt de Coyote HTTP/1.1 sur http-8180
10 avr. 2009 13:26:33 org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: Failed shutdown of Apache Portable Runtime
Hi Fabien,
Ciao,
Jeroen
View this message in context: http://n2.nabble.com/Error-with-geonetwork-when-stopping-Tomcat-tp2615179p2615731.html
Hello Fabien,
If you're using 2.1, maybe you should apply this fix for Intermap
http://n2.nabble.com/SF.net-SVN%3A-geonetwork%3A-1557--trunk-src-org-wfp-vam-intermap-kernel--TempFiles.java-td2022193.html#a2022193
HTH. Francois
2009/4/10 FBachraty <Fabien.Bachraty@anonymised.com>:
Thank you Jeroen,
I put :
on catalina.sh
Is that correct ?
... 29 more
Hi Fabien,
Ciao,
Jeroen
http://p.sf.net/sfu/www-ibm-com
You must be right François !
For the moment I just delete the intermap module on tomcat server.xml and the stopping work well.
Next week I will try the fix you provided to me and I will inform you of the result.
But regarding the context it is certainly the solution.
Thank you.
Hello Fabien,
HTH. Francois
View this message in context: http://n2.nabble.com/Error-with-geonetwork-when-stopping-Tomcat-tp2615179p2615854.html
