[GeoNetwork-users] Error with URL returned in status change emails
Hi list,
I'm sorry if I hijack this thread, but I think this is a good point where to
note this thing:
In the urlrewrite.xml there's a rule at the top to fix the language codes
from old GeoNetwork versions:
    <rule>
        <from>^(.*)/en/(.*)$</from>
        <to type="permanent-redirect"
last="true">%{context-path}$1/eng/$2</to>
    </rule>
The urlrewite doc reports, about the "last" attribute:
last: (optional)
  - false (default) The rest of the "rules" will be processed if this one
succeeds.
  - true No more "rules" will be processed if this one is a match.
I guess that the rules needed for remapping language codes should have
last="false" in order not to block custom rules appended at the end of the
list.
   Emanuele
Alle 09:00:18 di Friday 6 March 2015, Jose Garcia ha scritto:
Hi Jo
See comments inline.
Jose García
On Thu, Mar 5, 2015 at 12:53 PM, Jo Cook <jocook@anonymised.com> wrote:
> Hi Jose,
> We're not really in a position to build the code, so we're trying to get
> around this issue with the search URL using URLRewrite.xml. Unfortunately
> this seems to be having problems with the "#" sign in the URL, which we
> need to remove so we can switch from
> /srv/en/search#fast=index&from=1&to=50&_status=4&_statusChangeDate=2015-0
> 3-02T10:43:42 to
> /srv/eng/main.search?from=1&to=50&_status=4&_statusChangeDate=2015-03-02T
> 10:43:42
> We've tried loads of different rules but this one looks like it should
> work, but it doesn't (whether or not we use & or &amp;):
> <rule>
> <from>^(.*)/en/search#fast=index&amp;(.*)$</from>
> last="true">%{context-path}$1/eng/main.search?$2</to>
> </rule>
> If we take out the #fast=index section then the rule fires but it returns
> all metadata rather than the search results.
    <rule>
    </rule>
I think can matching the
(/srv/en/search#fast=index&from=1&to=50&_status=4&_statusChangeDate=2015-03
-02T10:43:42) url. Check to put your rule before this one (you'll need to
restart GeoNetwork to take effect the change).
> We've looked into the urlrewriter documentation and can find no reason
> why this should be a problem.
> Is this really the only way of dealing with the problem? Surely since we
> have configured geonetwork to always use the classic interface (in
> config-gui.xml) it should NEVER try and use the html5 interface anyhow?
> This seems like a bug? Unless we are missing something in config-gui.xml?
The problem is that the DefaultStatusActions class has hardcoded to use the
html5ui for mail content, independently of the config-gui.xml
> Thanks
> Jo
> Jo
> On Tue, Mar 3, 2015 at 7:19 AM, Jose Garcia <jose.garcia@anonymised.com>
> wrote:
>> Hi
>> Seem not directly configurable. If you can build the code, the fastest
>> is to set that flag to false in your case.
>> A generic option is to make it configurable in WEB-INF/config.xml, a way
>> to handle this can be the following.
>> 1) The DefaultStatusActions in setup in the GeoNetwork class:
>> https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/w
>> ebapp/WEB-INF/config.xml#L376
>> You can add a new parameter to the GeoNetwork class configuration in
>> WEB-INF/config.xml:
>> <param name="useHtml5ui" value="true"/>
>> 2) Change the code in GeoNetwork class where is initialised the
>> DefaultStatusActions: to manage this new configuration and update the
>> property in DefaultStatusActions
>> https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/j
>> ava/org/fao/geonet/Geonetwork.java#L179
>> Regards,
>> Jose García
>> On Mon, Mar 2, 2015 at 7:27 PM, Antony Scott <
>> antonyscott@anonymised.com> wrote:
>>> Hi Jose
>>> Just following up on the search URL issue Jo raised today - it seems
>>> from this:
>>> java/org/fao/geonet/services/metadata/DefaultStatusActions.java#L310
>>> that the html5ui param is set to true, which is why we are getting the
>>> HTML5 UI rather than the classic one in the search results. Is there
>>> some way we can set this to false? If not, we were looking at using
>>> the urlrewrite.xml file, but would rather set the html5ui param to
>>> the correct value if we can.
>>> many thanks
>>> Ant
>>> On 2 March 2015 at 14:53, Jo Cook <jocook@anonymised.com> wrote:
>>>> Hi Jose,
>>>> Apologies, I have found and fixed that error. However, the link in the
>>>> emails goes to the search interface rather than the classic. What do I
>>>> need
>>>> to change (and where) to ensure that only the classic interface is
>>>> used?
>>>> Thanks
>>>> Jo
>>>> On Mon, Mar 2, 2015 at 2:43 PM, Jo Cook <jocook@anonymised.com>
>>>> wrote:
>>>> > Hi Jose,
>>>> > In catalina.out I can now see the following error:
>>>> > 2015-03-02 10:41:15,668 INFO [jeeves.service] - ->
>>>> > transforming
>>>> with
>>>> > stylesheet : /var/lib/tomcat6/webapps/geonetwork/xsl/search.xsl
>>>> > Error at xsl:call-template on line 26 column 61 of metadata-edit.xsl:
>>>> > XTSE0090: Attribute @select is not allowed on element
>>>> <xsl:call-template>
>>>> > Originally I had two of these errors, one for line 27 column 61, and
>>>> > I have resolved that- but I can't see where the second example is.
>>>> > Have
>>>> you
>>>> > any pointers on where I should be looking?
>>>> > Jo
>>>> > On Mon, Mar 2, 2015 at 12:35 PM, Jose Garcia
>>>> > wrote:
>>>> >> Hi Jo
>>>> >> All the printStackTrace() only go to the catalina.out or to the
>>>> console,
>>>> >> not to geonetwork.log. The messages logged with the logger classes
>>>> should
>>>> >> end in both places.
>>>> >> Regards,
>>>> >> Jose García
>>>> >> On Mon, Mar 2, 2015 at 1:31 PM, Jo Cook
>>>> >> wrote:
>>>> >>> Hi Jose,
>>>> >>> Brilliant, thanks. I didn't even realise that catalina.out has
>>>> different
>>>> >>> messages in it compared to the geonetwork.log file, so I've learnt
>>>> >>> something new!
>>>> >>> Jo
>>>> >>> On Mon, Mar 2, 2015 at 12:25 PM, Jose Garcia <
>>>> >>> wrote:
>>>> >>>> Hi Jo
>>>> >>>> If using Tomcat, check in the catalina.out for
>>>> >>>> TransformerConfigurationException, usually contains the exact
>>>> >>>> xslt file and line where the error happens.
>>>> >>>> I guess that can help to find the issue better.
>>>> >>>> Regards,
>>>> >>>> Jose García
>>>> >>>> On Mon, Mar 2, 2015 at 1:10 PM, Jo Cook <
>>>> >>>> wrote:
>>>> >>>>> Hi List,
>>>> >>>>> Our geonetwork instance (2.10.4, tomcat6) is successfully
>>>> >>>>> sending emails
>>>> >>>>> when the status of a record changes, but the URL leads to an
>>>> >>>>> error message,
>>>> >>>>> and the log files are not helping me to understand where the
>>>> problem
>>>> >>>>> is.
>>>> >>>>> The URL is of the form
>>>> http://URL/geonetwork/srv/eng/search#fast=index&from=1&to=50&_status=4
>>>> >>>>> With debug switched on for searches in log4j.cfg I see the
>>>> following:
>>>> >>>>> 2015-03-02 12:07:19,907 ERROR [jeeves.service] - -> exception
>>>> during
>>>> >>>>> transformation for : search
>>>> >>>>> 2015-03-02 12:07:19,907 ERROR [jeeves.service] - -> (C)
>>>> stylesheet
>>>> message
>>>> >>>>> Failed to compile stylesheet. 2 errors detected.
>>>> exception
>>>> >>>>> 2015-03-02 12:07:19,908 DEBUG [jeeves.service] - Raised
>>>> >>>>> exception
>>>> while
>>>> >>>>> executing service
>>>> >>>>> <error id="error">
>>>> >>>>> <message>Failed to compile stylesheet. 2 errors
>>>> detected.</message>
>>>> >>>>> <class>TransformerConfigurationException</class>
>>>> >>>>> <stack>
>>>> >>>>> <at class="net.sf.saxon.PreparedStylesheet"
>>>> >>>>> file="PreparedStylesheet.java" line="176" method="prepare" />
>>>> >>>>> <at class="net.sf.saxon.TransformerFactoryImpl"
>>>> >>>>> file="TransformerFactoryImpl.java" line="139"
>>>> method="newTemplates" />
>>>> >>>>> <at
>>>> >>>>> class="de.fzi.dbs.xml.transform.CachingTransformerFactory"
>>>> >>>>> file="CachingTransformerFactory.java" line="120"
>>>> >>>>> method="newTransformer" />
>>>> >>>>> <at
>>>> >>>>> file="CachingTransformerFactory.java" line="76"
>>>> >>>>> <at class="jeeves.utils.Xml" file="Xml.java" line="520"
>>>> >>>>> method="transform" />
>>>> >>>>> <at class="jeeves.utils.Xml" file="Xml.java" line="418"
>>>> >>>>> <at class="jeeves.server.dispatchers.ServiceManager"
>>>> >>>>> file="ServiceManager.java" line="790" method="dispatchOutput" />
>>>> >>>>> file="ServiceManager.java" line="450" method="dispatch" />
>>>> >>>>> file="ServiceManager.java" line="362" method="dispatch" />
>>>> >>>>> <at class="jeeves.server.JeevesEngine"
>>>> file="JeevesEngine.java"
>>>> >>>>> line="811" method="dispatch" />
>>>> >>>>> <at class="jeeves.server.sources.http.JeevesServlet"
>>>> >>>>> file="JeevesServlet.java" line="216" method="execute" />
>>>> >>>>> file="JeevesServlet.java" line="115" method="doGet" />
>>>> >>>>> <skip>...</skip>
>>>> >>>>> <at
>>>> >>>>> class="org.fao.geonet.monitor.webapp.WebappMetricsFilter"
>>>> >>>>> file="WebappMetricsFilter.java" line="96" method="doFilter" />
>>>> >>>>> <skip>...</skip>
>>>> >>>>> <at
>>>> class="org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter"
>>>> >>>>> file="MetricsRegistryInitializerFilter.java" line="31"
>>>> >>>>> <skip>...</skip>
>>>> >>>>> <at
>>>> class="jeeves.config.springutil.GeonetworkFilterSecurityInterceptor"
>>>> >>>>> file="GeonetworkFilterSecurityInterceptor.java" line="46"
>>>> >>>>> method="invoke" />
>>>> >>>>> <skip>...</skip>
>>>> >>>>> <at
>>>> >>>>> method="invoke" />
>>>> >>>>> <skip>...</skip>
>>>> >>>>> <at class="org.fao.geonet.kernel.security.PassthroughFilter"
>>>> >>>>> file="PassthroughFilter.java" line="26" method="doFilter" />
>>>> >>>>> <skip>...</skip>
>>>> >>>>> </stack>
>>>> >>>>> <request>
>>>> >>>>> <language>eng</language>
>>>> >>>>> <service>search</service>
>>>> >>>>> </request>
>>>> >>>>> <request>
>>>> >>>>> <tmp />
>>>> >>>>> <user>
>>>> >>>>> user
>>>> >>>>> <authenticated>true</authenticated>
>>>> >>>>> <name>admin</name>
>>>> >>>>> <username>admin</username>
>>>> >>>>> <profile>Administrator</profile>
>>>> >>>>> </user>
>>>> >>>>> </request>
>>>> >>>>> </error>
>>>> >>>>> 2015-03-02 12:07:19,908 INFO [jeeves.service] - ->
>>>> dispatching to
>>>> >>>>> error
>>>> >>>>> for : search
>>>> >>>>> 2015-03-02 12:07:19,961 INFO [jeeves] - Overrides being applied
>>>> to
>>>> >>>>> configuration file: .*/WEB-INF/config-gui.xml
>>>> >>>>> 2015-03-02 12:07:19,961 INFO [jeeves] - Replacing child xml
>>>> elements
>>>> >>>>> of
>>>> >>>>> languages
>>>> >>>>> 2015-03-02 12:07:19,961 DEBUG [jeeves] - New elements
>>>> >>>>> are:<toAdd>
>>>> >>>>> <eng />
>>>> >>>>> </toAdd>
>>>> >>>>> 2015-03-02 12:07:19,961 DEBUG [jeeves] - replacingXML of
>>>> >>>>> /config/languages
>>>> elements
>>>> >>>>> of
>>>> >>>>> proj
>>>> >>>>> are:<toAdd>
>>>> >>>>> <crs code="EPSG:4326" default="1" edit="1" />
>>>> >>>>> <crs code="EPSG:27700" edit="1" def="+proj=tmerc +lat_0=49
>>>> +lon_0=-2
>>>> >>>>> +k=0.9996012717 +x_0=400000 +y_0=-100000 +ellps=airy
>>>> >>>>> +datum=OSGB36 +units=m
>>>> >>>>> +no_defs " />
>>>> >>>>> </toAdd>
>>>> >>>>> 2015-03-02 12:07:19,961 INFO [jeeves] - Replacing attribute
>>>> options of
>>>> >>>>> node mapSearch
>>>> >>>>> 2015-03-02 12:07:19,961 DEBUG [jeeves] - New attribute
>>>> is:{projection:
>>>> >>>>> 'EPSG:27700', maxExtent: new
>>>> OpenLayers.Bounds(0,0,700000,1300000),
>>>> >>>>> units:
>>>> >>>>> 'm', restrictedExtent: new
>>>> >>>>> OpenLayers.Bounds(0,0,700000,1300000), resolutions:
>>>> >>>>> [1600,800,400,200,100,50,25,10,5,2.5,1,0.5,0.25]} 2015-03-02
>>>> >>>>> 12:07:19,961 DEBUG [jeeves] - Updating attibute of node
>>>> >>>>> /config/mapSearch
>>>> elements
>>>> >>>>> of
>>>> >>>>> mapSearch/layers
>>>> >>>>> 2015-03-02 12:07:19,962 DEBUG [jeeves] - New elements
>>>> >>>>> are:<toAdd>
>>>> >>>>> <layer server="
>>>> >>>>> http://t0.ads.astuntechnology.com/astuntechnology/osopen/service
>>>> >>>>> " tocName="OS Open" params="{layers: 'osopen', format:
>>>> >>>>> 'image/png'}" options="{isBaseLayer: true}" />
>>>> >>>>> </toAdd>
>>>> >>>>> 2015-03-02 12:07:19,962 DEBUG [jeeves] - replacingXML of
>>>> >>>>> /config/mapSearch/layers
>>>> >>>>> 2015-03-02 12:07:19,962 INFO [jeeves] - Replacing attribute
>>>> options of
>>>> >>>>> node mapViewer
>>>> >>>>> 2015-03-02 12:07:19,962 DEBUG [jeeves] - New attribute
>>>> is:{projection:
>>>> >>>>> OpenLayers.Bounds(-3276800,-3276800,3276800,3276800), units:
>>>> >>>>> [3200,1600,800,400,200,100,50,25,10,5,2.5,1,0.5]}
>>>> >>>>> 2015-03-02 12:07:19,962 DEBUG [jeeves] - Updating attibute of
>>>> >>>>> node /config/mapViewer
>>>> >>>>> 2015-03-02 12:07:19,962 INFO [jeeves] - Replacing child xml
>>>> elements
>>>> >>>>> of
>>>> >>>>> mapViewer
>>>> >>>>> are:<toAdd>
>>>> >>>>> <layers>
>>>> >>>>> <layer server="
>>>> >>>>> " tocName="OS Open" params="{layers: 'oso2015-03-02 12:07:19,907
>>>> ERROR
>>>> >>>>> [jeeves.service] - -> exception during transformation for :
>>>> search
>>>> stylesheet
>>>> message
>>>> exception
>>>> >>>>> exception
>>>> while
>>>> >>>>> executing service
>>>> >>>>> <error id="error">
>>>> detected.</message>
>>>> >>>>> <stack>
>>>> >>>>> <at
>>>> >>>>> <at
>>>> >>>>> <skip>...</skip>
>>>> >>>>> <at
>>>> >>>>> <skip>...</skip>
>>>> >>>>> <at
>>>> >>>>> <skip>...</skip>
>>>> >>>>> <at
>>>> >>>>> method="invoke" />
>>>> >>>>> <skip>...</skip>
>>>> >>>>> <at
>>>> >>>>> method="invoke" />
>>>> >>>>> <skip>...</skip>
>>>> >>>>> <skip>...</skip>
>>>> >>>>> </stack>
>>>> >>>>> <request>
>>>> >>>>> </request>
>>>> >>>>> <request>
>>>> >>>>> <tmp />
>>>> >>>>> <user>
>>>> >>>>> user
>>>> >>>>> <name>admin</name>
>>>> >>>>> </user>
>>>> >>>>> </request>
>>>> >>>>> </error>
>>>> dispatching to
>>>> >>>>> error
>>>> >>>>> for : search
>>>> to
>>>> elements
>>>> >>>>> of
>>>> >>>>> languages
>>>> >>>>> are:<toAdd>
>>>> >>>>> <eng />
>>>> >>>>> </toAdd>
>>>> >>>>> /config/languages
>>>> elements
>>>> >>>>> of
>>>> >>>>> proj
>>>> >>>>> are:<toAdd>
>>>> +lon_0=-2
>>>> >>>>> +no_defs " />
>>>> >>>>> </toAdd>
>>>> options of
>>>> >>>>> node mapSearch
>>>> is:{projection:
>>>> >>>>> units:
>>>> >>>>> /config/mapSearch
>>>> elements
>>>> >>>>> of
>>>> >>>>> mapSearch/layers
>>>> >>>>> are:<toAdd>
>>>> >>>>> <layer server="
>>>> >>>>> </toAdd>
>>>> options of
>>>> >>>>> node mapViewer
>>>> is:{projection:
>>>> elements
>>>> >>>>> of
>>>> >>>>> mapViewer
>>>> >>>>> are:<toAdd>
>>>> >>>>> <layers>
>>>> >>>>> <layer server="
>>>> >>>>> </layers>
>>>> >>>>> <scales values="" />
>>>> >>>>> <proj>
>>>> >>>>> <crs code="EPSG:27700" default="1" name="BNG" />
>>>> >>>>> </proj>
>>>> >>>>> <servers>
>>>> >>>>> <server name="ADS" url="
>>>> >>>>> </servers>
>>>> >>>>> </toAdd>
>>>> >>>>> /config/mapViewer
>>>> >>>>> 2015-03-02 12:07:19,963 INFO [jeeves.service] - ->
>>>> transforming
>>>> >>>>> with
>>>> >>>>> stylesheet : /var/lib/tomcat6/webapps/geonetwork/xsl/error.xsl
>>>> >>>>> 2015-03-02 12:07:19,988 INFO [jeeves.service] - -> end
>>>> >>>>> error transformation for : search
>>>> >>>>> 2015-03-02 12:07:19,988 INFO [jeeves.service] - -> error
>>>> ended for
>>>> >>>>> search
>>>> >>>>> pen', format: 'image/png'}" options="{isBaseLayer: true}" />
>>>> >>>>> </layers>
>>>> >>>>> <proj>
>>>> >>>>> </proj>
>>>> >>>>> <servers>
>>>> >>>>> </servers>
>>>> >>>>> </toAdd>
>>>> >>>>> /config/mapViewer
>>>> transforming
>>>> >>>>> with
>>>> ended for
>>>> >>>>> search
>>>> >>>>> I can see that there are two errors detected but I don't know
>>>> where to
>>>> >>>>> start looking for the solution. Can anyone assist?
>>>> >>>>> Thanks
>>>> >>>>> Jo
>>>> >>>>> *Jo Cook*
>>>> >>>>> Astun Technology Ltd, The Coach House, 17 West Street, Epsom,
>>>> Surrey,
>>>> >>>>> KT18
>>>> >>>>> 7RL, UK
>>>> >>>>> t:+44 7930 524 155
>>>> >>>>> iShare - Data integration and publishing platform
>>>> >>>>> <http://www.isharemaps.com/&gt;
>>>> >>>>> Company registration no. 5410695. Registered in England and
>>>> Wales.
>>>> >>>>> Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN
>>>> VAT
>>>> >>>>> no.
>>>> >>>>> 864201149.
>>>> >>>>> Dive into the World of Parallel Programming The Go Parallel
>>>> Website,
>>>> >>>>> sponsored
>>>> >>>>> by Intel and developed in partnership with Slashdot Media, is
>>>> your hub
>>>> >>>>> for all
>>>> >>>>> things parallel software development, from weekly thought
>>>> leadership
>>>> >>>>> blogs to
>>>> >>>>> news, videos, case studies, tutorials and more. Take a look and
>>>> join
>>>> >>>>> the
>>>> >>>>> conversation now. http://goparallel.sourceforge.net/
>>>> >>>>> _______________________________________________
>>>> >>>>> GeoNetwork-users mailing list
>>>> >>>>> GeoNetwork-users@lists.sourceforge.net
>>>> >>>>> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
>>>> >>>>> GeoNetwork OpenSource is maintained at
>>>> >>>>> http://sourceforge.net/projects/geonetwork
>>>> >>>> *GeoCat Bridge for ArcGIS allows instant publishing of data and
>>>> >>>> metadata on GeoServer and GeoNetwork. Visit http://geocat.net
>>>> >>>> <http://geocat.net/&gt; for details. _________________________Jose
>>>> >>>> GarcíaGeoCat bvVeenderweg 136721 WD BennekomThe
>>>> >>>> Netherlandshttp://GeoCat.net/>*
>>>> >>> *Jo Cook*
>>>> Surrey,
>>>> >>> KT18 7RL, UK
>>>> >>> t:+44 7930 524 155
>>>> >>> Wales.
>>>> VAT no.
>>>> >>> 864201149.
>>>> metadata
>>>> > *Jo Cook*
>>>> > Surrey,
>>>> KT18
>>>> > 7RL, UK
>>>> > t:+44 7930 524 155
>>>> > Company registration no. 5410695. Registered in England and Wales.
>>>> > Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT
>>>> no.
>>>> > 864201149.
>>>> *Jo Cook*
>>>> Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey,
>>>> KT18
>>>> 7RL, UK
>>>> t:+44 7930 524 155
>>>> no. 864201149.
>>>> -------- Dive into the World of Parallel Programming The Go Parallel
>>>> Website, sponsored
>>>> by Intel and developed in partnership with Slashdot Media, is your hub
>>>> for all
>>>> things parallel software development, from weekly thought leadership
>>>> blogs to
>>>> news, videos, case studies, tutorials and more. Take a look and join
>>>> the conversation now. http://goparallel.sourceforge.net/
>>> *Antony Scott*
>>> KT18 7RL, UK
>>> t:+44 7866 455 515
>>> no. 864201149.
>> *GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
> *Jo Cook*
> KT18 7RL, UK
> t:+44 7930 524 155
> Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
> 864201149.
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
I implemented the suggested fix here:
   https://github.com/geonetwork/core-geonetwork/pull/864
The default values are set so that GN behaves the same as before
so you have to change this value (or use an override) in order to create the
proper URLs in the notification mails.
I'll merge the pullreq in a couple of days.
   Emanuele
Alle 08:19:20 di Tuesday 3 March 2015, Jose Garcia ha scritto:
Hi
Seem not directly configurable. If you can build the code, the fastest is
A generic option is to make it configurable in WEB-INF/config.xml, a way to
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/weba
WEB-INF/config.xml:
https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/java
Jose García
> Hi Jose
> Just following up on the search URL issue Jo raised today - it seems from
> this:
> HTML5 UI rather than the classic one in the search results. Is there some
> way we can set this to false? If not, we were looking at using the
> urlrewrite.xml file, but would rather set the html5ui param to the
> many thanks
> Ant
>> Hi Jose,
>> need
>> to change (and where) to ensure that only the classic interface is used?
>> Thanks
>> Jo
>> wrote:
>> > Hi Jose,
>> > 2015-03-02 10:41:15,668 INFO [jeeves.service] - -> transforming
>> with
>> <xsl:call-template>
>> > Originally I had two of these errors, one for line 27 column 61, and I
>> > have resolved that- but I can't see where the second example is. Have
>> you
>> > Jo
>> > On Mon, Mar 2, 2015 at 12:35 PM, Jose Garcia <jose.garcia@anonymised.com>
>> > wrote:
>> >> Hi Jo
>> console,
>> should
>> >> end in both places.
>> >> Regards,
>> >> Jose García
>> >> On Mon, Mar 2, 2015 at 1:31 PM, Jo Cook <jocook@anonymised.com>
>> >> wrote:
>> >>> Hi Jose,
>> different
>> >>> something new!
>> >>> Jo
>> >>> wrote:
>> >>>> Hi Jo
>> >>>> TransformerConfigurationException, usually contains the exact xslt
>> >>>> Regards,
>> >>>> Jose García
>> >>>> wrote:
>> >>>>> Hi List,
>> >>>>> Our geonetwork instance (2.10.4, tomcat6) is successfully sending
>> >>>>> emails
>> >>>>> when the status of a record changes, but the URL leads to an error
>> >>>>> message,
>> >>>>> problem is.
>> http://URL/geonetwork/srv/eng/search#fast=index&from=1&to=50&_status=4&_
>> following:
>> during
>> stylesheet
>> >>>>> message
>> exception
>> >>>>> 2015-03-02 12:07:19,908 DEBUG [jeeves.service] - Raised exception
>> while
>> >>>>> executing service
>> >>>>> <error id="error">
>> detected.</message>
>> >>>>> <stack>
>> >>>>> <at class="de.fzi.dbs.xml.transform.CachingTransformerFactory"
>> >>>>> <skip>...</skip>
>> >>>>> <at class="org.fao.geonet.monitor.webapp.WebappMetricsFilter"
>> >>>>> <skip>...</skip>
>> >>>>> <at
>> >>>>> <skip>...</skip>
>> >>>>> <at
>> >>>>> r" file="GeonetworkFilterSecurityInterceptor.java" line="46"
>> >>>>> method="invoke" />
>> >>>>> <skip>...</skip>
>> >>>>> <at
>> >>>>> method="invoke" />
>> >>>>> <skip>...</skip>
>> >>>>> <skip>...</skip>
>> >>>>> </stack>
>> >>>>> <request>
>> >>>>> </request>
>> >>>>> <request>
>> >>>>> <tmp />
>> >>>>> <user>
>> >>>>> user
>> >>>>> <name>admin</name>
>> >>>>> </user>
>> >>>>> </request>
>> >>>>> </error>
>> >>>>> 2015-03-02 12:07:19,908 INFO [jeeves.service] - -> dispatching
>> to
>> >>>>> error
>> >>>>> for : search
>> >>>>> to configuration file: .*/WEB-INF/config-gui.xml
>> elements
>> >>>>> of
>> >>>>> languages
>> >>>>> 2015-03-02 12:07:19,961 DEBUG [jeeves] - New elements are:<toAdd>
>> >>>>> <eng />
>> >>>>> </toAdd>
>> >>>>> /config/languages
>> elements
>> >>>>> of
>> >>>>> proj
>> +lon_0=-2
>> >>>>> +k=0.9996012717 +x_0=400000 +y_0=-100000 +ellps=airy +datum=OSGB36
>> >>>>> +units=m
>> >>>>> +no_defs " />
>> >>>>> </toAdd>
>> options of
>> >>>>> node mapSearch
>> is:{projection:
>> >>>>> OpenLayers.Bounds(0,0,700000,1300000), units:
>> >>>>> 'm', restrictedExtent: new OpenLayers.Bounds(0,0,700000,1300000),
>> >>>>> resolutions: [1600,800,400,200,100,50,25,10,5,2.5,1,0.5,0.25]}
>> >>>>> 2015-03-02 12:07:19,961 DEBUG [jeeves] - Updating attibute of node
>> >>>>> /config/mapSearch
>> elements
>> >>>>> of
>> >>>>> mapSearch/layers
>> >>>>> 2015-03-02 12:07:19,962 DEBUG [jeeves] - New elements are:<toAdd>
>> >>>>> <layer server="
>> >>>>> http://t0.ads.astuntechnology.com/astuntechnology/osopen/service&quot;
>> >>>>> tocName="OS Open" params="{layers: 'osopen', format: 'image/png'}"
>> >>>>> </toAdd>
>> options of
>> >>>>> node mapViewer
>> is:{projection:
>> >>>>> OpenLayers.Bounds(-3276800,-3276800,3276800,3276800), units: 'm',
>> >>>>> resolutions:
>> >>>>> 2015-03-02 12:07:19,962 DEBUG [jeeves] - Updating attibute of node
>> >>>>> /config/mapViewer
>> elements
>> >>>>> of
>> >>>>> mapViewer
>> >>>>> <layers>
>> >>>>> <layer server="
>> >>>>> ERROR
>> search
>> stylesheet
>> >>>>> message
>> exception
>> while
>> >>>>> executing service
>> >>>>> <error id="error">
>> detected.</message>
>> >>>>> <stack>
>> >>>>> <skip>...</skip>
>> >>>>> <skip>...</skip>
>> >>>>> <at
>> >>>>> <skip>...</skip>
>> >>>>> <at
>> >>>>> method="invoke" />
>> >>>>> <skip>...</skip>
>> >>>>> <at
>> >>>>> method="invoke" />
>> >>>>> <skip>...</skip>
>> >>>>> <skip>...</skip>
>> >>>>> </stack>
>> >>>>> <request>
>> >>>>> </request>
>> >>>>> <request>
>> >>>>> <tmp />
>> >>>>> <user>
>> >>>>> user
>> >>>>> <name>admin</name>
>> >>>>> </user>
>> >>>>> </request>
>> >>>>> </error>
>> to
>> >>>>> error
>> >>>>> for : search
>> elements
>> >>>>> of
>> >>>>> languages
>> >>>>> <eng />
>> >>>>> </toAdd>
>> >>>>> /config/languages
>> elements
>> >>>>> of
>> >>>>> proj
>> +lon_0=-2
>> >>>>> +units=m
>> >>>>> +no_defs " />
>> >>>>> </toAdd>
>> options of
>> >>>>> node mapSearch
>> is:{projection:
>> >>>>> /config/mapSearch
>> elements
>> >>>>> of
>> >>>>> mapSearch/layers
>> >>>>> <layer server="
>> >>>>> </toAdd>
>> options of
>> >>>>> node mapViewer
>> is:{projection:
>> >>>>> resolutions:
>> >>>>> /config/mapViewer
>> elements
>> >>>>> of
>> >>>>> mapViewer
>> >>>>> <layers>
>> >>>>> <layer server="
>> >>>>> </layers>
>> >>>>> <proj>
>> >>>>> </proj>
>> >>>>> <servers>
>> >>>>> http://t0.ads.astuntechnology.com/astuntechnology/osopen/service?&quot;
>> >>>>> </servers>
>> >>>>> </toAdd>
>> >>>>> /config/mapViewer
>> transforming
>> >>>>> with
>> >>>>> 2015-03-02 12:07:19,988 INFO [jeeves.service] - -> end error
>> >>>>> 2015-03-02 12:07:19,988 INFO [jeeves.service] - -> error ended
>> for
>> >>>>> search
>> >>>>> </layers>
>> >>>>> <proj>
>> >>>>> </proj>
>> >>>>> <servers>
>> >>>>> </servers>
>> >>>>> </toAdd>
>> >>>>> /config/mapViewer
>> transforming
>> >>>>> with
>> for
>> >>>>> search
>> >>>>> where
>> to
>> >>>>> Thanks
>> >>>>> Jo
>> >>>>> *Jo Cook*
>> Surrey,
>> >>>>> KT18
>> >>>>> 7RL, UK
>> >>>>> t:+44 7930 524 155
>> >>>>> Wales.
>> >>>>> VAT no.
>> >>>>> 864201149.
>> >>>>> Website, sponsored
>> hub
>> >>>>> for all
>> >>>>> leadership blogs to
>> >>>>> join the
>> >>> *Jo Cook*
>> >>> Surrey, KT18 7RL, UK
>> >>> t:+44 7930 524 155
>> no.
>> >>> 864201149.
>> metadata
>> > *Jo Cook*
>> KT18
>> > 7RL, UK
>> > t:+44 7930 524 155
>> > no. 864201149.
>> *Jo Cook*
>> KT18 7RL, UK
>> t:+44 7930 524 155
>> 864201149.
>> Website, sponsored
>> for all
>> blogs to
>> news, videos, case studies, tutorials and more. Take a look and join the
> *Antony Scott*
> KT18 7RL, UK
> t:+44 7866 455 515
> 864201149.
Technical Lead
