Hi Geo network Users
I am having a few issues with iso19139.anzlic and 3.4.3.
The submodule for the iso standard compiles fine with 3.4.3. However when I go to test the software after compiling with.
cd web; mvn jetty:run
I get exception errors thrown by jetty see below complaining about the iso19139.anzlic schema.
FileError:
'http://localhost:8080/geonetwork/catalog/lib/style/bootstrap-3.0.1/bootstrap.less’
wasn't found (404)
in bootstrap.less <http://localhost:8080/geonetwork/catalog/lib/style/bootstrap-3.0.1/bootstrap.less>
Raised exception while starting the application. Fix the error and
restart.
*Message*
Failed whilst validating schema-ident file /home/arae/src/java/geonetwork_3.4.3/core-geonetwork/web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139.anzlic/schema-ident.xml. Exception message if any is XSD Validation error(s):
<xsderrors>
<error>
<typeOfError>ERROR</typeOfError>
<errorNumber>1</errorNumber>
<message>cvc-complex-type.2.4.a: Invalid content was found starting with element 'depends'. One of '{"http://geonetwork-opensource.org/schemas/schema-ident":appMinorVersionSupported\}' is expected. (Element: depends with parent element: schema)</message>
<xpath>depends</xpath>
</error>
</xsderrors>
*Handler*
org.fao.geonet.Geonetwork
*Exception*
OperationAbortedEx : Failed whilst validating schema-ident file /home/arae/src/java/geonetwork_3.4.3/core-geonetwork/web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139.anzlic/schema-ident.xml. Exception message if any is XSD Validation error(s):
<xsderrors>
<error>
</error>
</xsderrors>
*Stack*
<xsderrors>
<error>
</error>
</xsderrors>
at org.fao.geonet.kernel.SchemaManager.processSchema(SchemaManager.java:1289)
at org.fao.geonet.kernel.SchemaManager.configure(SchemaManager.java:224)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:243)
at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:448)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:191)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:84)
at javax.servlet.GenericServlet.init(GenericServlet.java:244)
at org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:640)
at org.eclipse.jetty.servlet.ServletHolder.initialize(ServletHolder.java:419)
at org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:875)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:349)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1404)
at org.eclipse.jetty.maven.plugin.JettyWebAppContext.startWebapp(JettyWebAppContext.java:323)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1366)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:772)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:262)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:520)
at org.eclipse.jetty.maven.plugin.JettyWebAppContext.doStart(JettyWebAppContext.java:398)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:132)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:114)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:61)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:161)
at org.eclipse.jetty.server.Server.start(Server.java:411)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:106)
at org.eclipse.jetty.server.Server.doStart(Server.java:378)
at org.eclipse.jetty.maven.plugin.AbstractJettyMojo.startJetty(AbstractJettyMojo.java:460)
at org.eclipse.jetty.maven.plugin.AbstractJettyMojo.execute(AbstractJettyMojo.java:328)
at org.eclipse.jetty.maven.plugin.JettyRunMojo.execute(JettyRunMojo.java:170)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:863)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:288)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:199)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: XSDValidationErrorEx : XSD Validation error(s):
<xsderrors>
<error>
</error>
</xsderrors>
at org.fao.geonet.utils.Xml.validate(Xml.java:878)
at org.fao.geonet.utils.Xml.validate(Xml.java:862)
at org.fao.geonet.kernel.SchemaManager.processSchema(SchemaManager.java:1275)
... 58 more
