I'm looking for a method of getting ESRI xml metadata into Geonetwork in
ISO19139 format.
Is anyone else looking at this and may have some advice on the way forward?
Tony Hunter (GISP - AP)
Risk & Impact Analysis Group | Geospatial & Earth Monitoring Division
Geoscience Australia | GPO Box 378, Canberra, ACT 2601, Australia
* +61 2 62499362 | Fax: +61 2 62499911 | * Tony.Hunter@anonymised.com
Internet: http://www.ga.gov.au
GIS Professional - Asia Pacific
Certified Professional, Spatial Sciences Institute
www.spatialsciences.org.au | www.gisp-ap.net
You could give the Spatial Data Integrator a try..
http://www.spatialdataintegrator.com/
There have been other strategies posted on the list before as well.
Hope this helps and good luck.
Jason
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On Behalf Of
Sent: Wednesday, February 27, 2008 3:24 AM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] ESRI to ISO19139 tools
ISO19139 format.
forward?
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-users mailing list
Hi Tony,
On Feb 27, 2008, at 3:24 AM, Tony.Hunter@anonymised.com wrote:
ISO19139 format.
As you may have seen, there's a conversion from ArcCat v8 & v9.0 ISO metadata into ISO19115:DIS. There is also a conversion from ISO19115:DIS into ISO19139 encoded metadata. So you could combine those XSLTs to convert ISO metadata created in the wizard of those versions of ArcCatalog.
I have to investigate what the current metadata format of ArcGIS 9.2 is to understand what is required.
Possibly it supports 19139 already!? In that case, the transformation could be done on the ArcCatalog side without problems.
What version of ArcGIS are you looking at?
Ciao,
Jeroen
