has anyone experiences with the test-suite "teamengine" from the GDI-DE
in germany and geonetwork? This test suite checks in six levels the csw
from geonetwork. In a project we have to pass these six levels with
geonetwork.
The levels and the our results are
- Interface- and Binding-Availability (Level 1.1) => passed
- Correctness of Request- and Response-Structures (Level 1.2) passed
- Correctness of Results (Level 1.3) => failed
- Support for Service-Metadata (Level 1.4) => failed
- Multi-Language (Level 1.5) => passed
- INSPIRE Conformance (Level 1.6) => failed
The test-suite is availible under
http://testsuite.gdi-de.org/teamengine/
Thanks for advices
Martin
Hi Martin
In the folder cswtests (from source code) are integrated these test, to run
with ant. There's a readme file explaining how to use it.
Not sure about the version of tests, but should not be difficult to update
them to a newer version if exists.
Jose García
On Wed, Jul 13, 2011 at 12:01 PM, Martin Hüben <martin.hueben@anonymised.com
wrote:
geonetwork.
Thanks for advices
Martin
AppSumo Presents a FREE Video for the SourceForge Community by Eric
Ries, the creator of the Lean Startup Methodology on "Lean Startup
Secrets Revealed." This video shows you how to validate your ideas,
optimize your ideas and identify your business strategy.
http://p.sf.net/sfu/appsumosfdev2dev
GeoNetwork-users mailing list
