[GeoNetwork-users] Explorer operations and footprint drawing [SEC=UNCLASSIFIED]
Hi Fabio,
I don't have a answer to your question but I do have an architectural
suggestion that may help. One of the good things about ebRIM is that once
you have found an object in the registry you can link off to an extrinsic (is
that the word?) object. These objects can be services internal or external
to the ebRIM registry.
I know that GN doesn't currently do this but it may be a consideration for
future versions. ebRIM does have its good points but it also has some bad
ones. ;--)
Thanks and sorry for not answering your question. ;--)
John
-----Original Message-----
From: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] On
Behalf Of Fabio D'Ovidio
Sent: Tuesday, 4 September 2007 6:39 PM
To: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Explorer operations and
footprint drawing
Hi Tim! Hi list!
Tim, thank u for your replay!
I've read somenthing and I have my own idea: with GN I can
manage metadata, not data
itself unless it is a standrd WMS link to a Map Server (in
this case i can use interactive map
through Intermap, is it true?).
So, if my data is on the file system (or managed by not
standard Image Servicecs) I can't
display it with Intermap. I understand what u mean, so I
could make a spatial search with
Intermap and find data in GN (through metadata)..but can u
give me any link to a sample
application that do this? Until now I have only see
applications in which metadata stored in
GN and data displayed in Intermap are separated.
With GN I would like to:
1. do spatial search in the sense described above
2. display image footprints (through coordinates stored as
metadata in GN)
3. do explorer operation like: create folder, copy, paste data, ecc..
Is it possible (now or in the next release) to do vector data
upload in mySQL spatial or
PostGIS DBMS?
Thank u very much for your help !
Fabio D'Ovidio Software Engineer
Web GIS Staff
Planetek Italia s.r.l.
Via Massaua 12, I-70123 Bari
Tel.: +39 080 9644200 Fax: +39 080 5340280
dovidio@anonymised.com - http://www.planetek.it
On 3 Sep 2007 at 16:04, Tim Jacobs wrote:
> Hi Fabio,
> I'm no expert in these matters, but you should first start
by looking around
> on the GN website.
http://geonetwork-opensource.org/documentation/faq/foss-sdi-an
d-opensdi for
> instance gives a nice overview.
> GN in itself is a catalog server, which provides you with metadata
> basically. Incorporating Intermap (a map viewer) allows GN
users to do
> geographical searches on the metadata via a map interface.
> Once the proper metadata has been found, then users can
switch to WMS's like
> MapServer, GeoServer etc for WMS interfacing or WCS servers to get
> coverages, etc.
> So, in short, Intermap lets you select coordinates, which
are then passed to
> GN for metadata retrieval from the database.
> Cheers,
> Tim
> >From: "Fabio D'Ovidio" <dovidio@anonymised.com>
> >Reply-To: dovidio@anonymised.com
> >To: "Tim Jacobs" <jacobs_tim100@anonymised.com>
> >Subject: RE: [GeoNetwork-users] Explorer operations and
footprint drawing
> >Date: Fri, 31 Aug 2007 16:47:25 +0200
> > > So, yes, you can show satellite footprint images,
provided that you
> >import
> > > them into GN using proper
> > > geographic metadata.
> >So, i can import my satellite image metadata in the DBMS
and catalogue them
> >in GN, but
> >Intermap is only a WMS client, or not? So in which way
Intermap can read
> >coordinates in the
> >metadata saved in the database? I mean..I have to develop
something, it's
> >ok..but i'd like to
> >know if there are any ready to use functionality to do that.
> >bye
> >Ing. Fabio D'Ovidio
> >Web GIS Staff
> _________________________________________________________________
> Looking for an old friend? You may find him in your
friends' friends list !
> http://spaces.live.com/default.aspx?page=Ed01&ss=True
Now Search log events and configuration files using AJAX and
a browser.
GeoNetwork-users mailing list
