[GeoNetwork-users] export created metadata with GAST
got another problem, thanks for any help:
With GAST I first import and then and export metadata originaly in the mef format from the directory gast\setup\sample-data of geonetwork, it works fine.
The metadata which is created using the input form (doesn't matter which template) is not beeing exported using the GAST export tool, without any error message.
Does anyone else noticed this problem?
Thanks.
Best regards,
Jan
You say that your exported file/metadata is not there? You can´t find it?
I would say that the import and export worked fine and you have to look at
your "download" folder if there are any files.
sorry if I misunderstood your question.
best regards
Sarah
Jan Schorn-3 wrote:
works fine.
error message.
Thanks.
Best regards,
Jan
Come build with us! The BlackBerry® Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9-12, 2009. Register
now!
http://p.sf.net/sfu/devconf
GeoNetwork-users mailing list
View this message in context: http://n2.nabble.com/export-created-metadata-with-GAST-tp3685695p3686314.html
Thats it, the exported files are not in the specified download folder if they wasn't imported by GAST (e.g. if they were created using the input form).
Any ideas?
Jan
Sarah_S wrote:
You say that your exported file/metadata is not there? You can´t find it? I would say that the import and export worked fine and you have to look at
best regards
Sarah
Jan Schorn-3 wrote:
Thanks.
Best regards,
Jan
developing skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9-12, 2009. Register
now!
hi jan,
don´t know if you have already solved your problem..but want to let you know
that your created metadata are saved at your db. Can you try using "search
unused metadata" and see your data?
regards
Sarah
form).
Any ideas?
Jan
at
best regards
Sarah
Jan Schorn-3 wrote:
works fine.
error message.
Thanks.
Best regards,
Jan
stay
now!
now!
View this message in context: http://n2.nabble.com/export-created-metadata-with-GAST-tp3685695p3735574.html
