[GeoNetwork-users] Export metadata as xml with 2.6
Hi list,
is there a possibility for exporting a metadata as xml to a local space?
I have a 2.6 .war version of geonetwork deployed at tomcat and I use win.
I read it could done via GAST but I have no GAST.
Any hints?
best regards
Sarah
Hi Sarah,
        I'm not sure what you mean by "local space", but you can export
data as XML within geonetwork (without GAST). Do the following:
        Search for desired metadata
        Select (with checkbox) the metadata (one or many) that you want to
export.
        Click "actions on selection" in the top-right.
        Go to "export (ZIP)"
        This will export the data as XML within a zip file. Each metadata
entry will have a seperate XML file if memory serves.
Hope that helps.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Jonathan,
thanks for this hint! That helped.
I was looking at administration page but could not find "export" only import.:wink:
best regards
Sarah
Hi Sarah,
        I'm not sure what you mean by "local space", but you can export data as
  1. Search for desired metadata
  2. Select (with checkbox) the metadata (one or many) that you want to
export.
  3. Click "actions on selection" in the top-right.
  4. Go to "export (ZIP)"
        This will export the data as XML within a zip file. Each metadata entry
Hope that helps.
Jonathan
