GAST allows you to export the metadata, thumbnails and uploaded resource
files from Geonetwork as a MEF archive.
GAST handles both export and import, just configure with the options
cofiguration tabs.
Therefore GAST is a useful tool for metadata backups as well as
transfers between Geonetwork instances.
If you just want to tranfer the metadata only, then export manually from
the icon at top right of the displayed entry, as in this example:
http://geonetwork.sopac.org/geonetwork/srv/en/metadata.show?id=93
Brian
> -------- Forwarded Message --------
> From: Kilmeny Stephens <kilmeny.stephens@anonymised.com>
> To: geonetwork-users@lists.sourceforge.net
> Subject: [GeoNetwork-users] Export question
> Date: Mon, 26 May 2008 11:53:19 +1200
> Hello,
> I may well be missing something obvious, so please excuse me if so...
> We have put in a few metadata records using a local install. We plan to
> switch to the server version (after doing some testing), and had hoped
> to export our original records, and then import to the server version,
> rather than redoing them.
> Is it possible to export to the MEF format from the local install? I
> can find where to import, but not export. Reading the "The complete
> manual", the only place I can find that explains exporting is using the
> GAST tool.
> Alternatively - can anyone suggest other methods for this transfer?
> Thanks,
> Kilmeny.
> Kilmeny Stephens
> Senior GIS Data Analyst
> Information Management
> Nelson City Council
> PO Box 645
> NELSON 7010
> NEW ZEALAND
> You are prohibited from distributing this E-mail without permission. If you have received this E-mail by mistake or are not the intended recipient, please notify the sender and erase the message immediately. This E-mail message and any accompanying data is confidential and may be legally privileged. The Nelson City Council does not warrant or guarantee that this communication is free of errors, virus or interference.
> This e-mail has been scanned and cleared by MailMarshal.
Brian Bishop
Coordinator Ocean Information Systems
Ocean and Islands Programme
SOPAC PACIFIC ISLANDS APPLIED GEOSCIENCE COMMISSION
Postal Address: Private Mail Bag, GPO, Suva, Fiji Islands
Street Address: 241 Mead Road, Suva, Fiji Islands
Tel: +679 338 1377
Fax: +679 337 0040
E-mail: brian@anonymised.com
Web site: http://geonetwork.sopac.org
