Thank you very much Jose Garcìa,
you were right!
I simply added the file to19139.xsl in my shema-plugin
and then I was able to export metadata.
Thanks again
Eugenio
Date: Wed, 4 Feb 2015 11:54:26 +0100
Subject: Re: [GeoNetwork-users] export zip error
To: frippe12573@anonymised.com
CC: geonetwork-users@lists.sourceforge.net
Hi Eugenio
Seem you have installed the iso19139.rndt metadata schema and some of the records you're exporting are from that schema, but seems doesn't exists the file convert/to19139.xsl.
Checking in GitHub the file is there (https://github.com/geonetwork/schema-plugins/blob/develop/iso19139.rndt/src/main/plugin/iso19139.rndt/convert/to19139.xsl), check if you have an old version of the metadata schema.
Regards,Jose García
On Wed, Feb 4, 2015 at 9:56 AM, Eugenio Trumpy <frippe12573@anonymised.com> wrote:
Hello everybody,
today I was trying to export some metadata from an instance of GN, to import them in another one.
However I got an error on export zip:
Requested transformation [/dati/webapps/geonetwork/WEB-INF/data/config/schema_plugins/iso19139.rndt/convert/to19139.xsl] does not exist
Actually I have the 19139.xsl schema, could you give me hints?
Regards
Eugenio
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
GeoNetwork-users mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details. _________________________Jose GarcíaGeoCat bvVeenderweg 136721 WD BennekomThe Netherlandshttp://GeoCat.net
