Dear communauty,
In a GN migration context (3.0.4 to 3.4.1), i wasn't able to migrate the database (unrecoverable errors)
So i decided to harvest my old catalog to < copy > existing metadata records in the new GN instance
But of course, a lot of information is lost during this process
As an example, is there an efficient way to get the directory containt (81 responsible party records) harvested and thus available for new records in the new Gn instance ?
Thanks for your help
Philippe
Hi Philippe, you could maybe have a look to the registries > collect API
which can be use to build a directory from existing records.
http://localhost:8080/geonetwork/doc/api/#/registries/extractEntries
HTH
Francois
Le jeu. 12 juil. 2018 à 11:59, Philippe Clastre <philippe.clastre@anonymised.com528...>
a écrit :
Dear communauty,
Philippe
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
Hi François
A few more questions : using the given URL, the returned message is : The service "/geonetwork_anaee/doc/api/" does not exist or you don't have privileges to access it
I’m logged in as administrator.
How should i activate this service in my GN (3.0.4 version) ?
I think you should know that i installed GN with a war file.
Thanks again.
Philippe
De : Francois Prunayre <fx.prunayre@...54...>
Envoyé : vendredi 13 juillet 2018 15:29
À : Philippe Clastre <philippe.clastre@...1528...>
Cc : Geonetwork-Users@...638...
Objet : Re: [GeoNetwork-users] Exporting directory containt
Hi Philippe, you could maybe have a look to the registries > collect API which can be use to build a directory from existing records.
HTH
Francois
Le jeu. 12 juil. 2018 à 11:59, Philippe Clastre <philippe.clastre@...1528...<mailto:philippe.clastre@…1528…>> a écrit :
Dear communauty,
Philippe
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
The REST API is part of the 3.2 and 3.4 version so you can use it once you
have your records imported in 3.4 to recreate your directory from the
records.
Francois
Le ven. 13 juil. 2018 à 17:36, Philippe Clastre <philippe.clastre@anonymised.com528...>
a écrit :
Hi François
Thanks again.
Philippe
*De :* Francois Prunayre <fx.prunayre@anonymised.com>
*Envoyé :* vendredi 13 juillet 2018 15:29
*À :* Philippe Clastre <philippe.clastre@anonymised.com>
*Cc :* Geonetwork-Users@anonymised.com
*Objet :* Re: [GeoNetwork-users] Exporting directory containt
HTH
Francois
Le jeu. 12 juil. 2018 à 11:59, Philippe Clastre <philippe.clastre@anonymised.com.1528...>
a écrit :
Dear communauty,
Philippe
