Greg,
Seems ok in 2.6.4 as well (tried both batch import from dir of xml files and copy/paste import)? Might need to see more info on how you're uploading this to GeoNetwork because I think this should work. Maybe the permissions on the uploaded record have not been set so that you/others can view the record?
Simon
________________________________________
Sent: Wednesday, 29 June 2011 5:09 PM
To: Gregory Giuliani
Cc: fx.prunayre@anonymised.com; geonetwork-users@lists.sourceforge.net
Subject: RE: [GeoNetwork-users] Exporting metadata from ArcCatalog to GN
Hi Greg and Francois,
Test record seems to import ok into 2.7 (schema detected is iso19139). I can see the metadata in the viewer etc. I'll check out what happens with 2.6.x now.
Simon
From: Gregory Giuliani [gregory.giuliani@anonymised.com]
Sent: Wednesday, 29 June 2011 12:21 AM
To: Pigot, Simon (CMAR, Hobart)
Subject: Re: [GeoNetwork-users] Exporting metadata from ArcCatalog to GN
Here is what my colleague is working with.
On Jun 28, 2011, at 4:17 PM, <Simon.Pigot@anonymised.com> wrote:
Hmm. Maybe the namespaces on the metadata document are different and thus the XML isn't handled by the XSLTs in GeoNetwork? Can you attach an example metadata record p[roduced by ArcCatalog ISO19139 export?
Simon
Sent: Wednesday, 29 June 2011 12:16 AM
Cc: geonetwork-users@lists.sourceforge.net
Hi Simon,
Thanks for your quick reaction.
Well in fact, the import is successful but there is no possibilities to look at the metadata record.
I looked to the database itself but any records were uploaded. And no error messages
Greg
On Jun 28, 2011, at 3:53 PM, <Simon.Pigot@anonymised.com> <Simon.Pigot@anonymised.com..> wrote:
Hi Greg,
Can you give us some more info on why the upload to GN failed? Did you get some error messages? I'd like to investigate this further as we also have other people asking about this.
Simon
Sent: Tuesday, 28 June 2011 11:41 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Exporting metadata from ArcCatalog to GN
Dear all,
With colleagues we are looking to find a simple (and potentially free) way to export metadata from ArcCatalog (9.x or 10) to GN 2.6.x
We have tried to export our metadata using the ISO19139 export but the upload to GN failed.
I've looked to several forums that this looks like a recurrent problem but did not find any "simple" solution.
Is there any simple way to do that? We know that there is GeoCat Bridge (and it looks great) but we are also looking for a solution that we can easily propose to project partners.
Thanks for your help.
Greg
Gregory Giuliani
Scientific collaborator - Spatial Data Infrastructure
University of Geneva/Institute for Environmental Sciences
Climatic Change and Climate Impacts/enviroSPACE
7 route de Drize, CH - 1227 CAROUGE
Phone: (+41 22) 379 07 09 Fax: (+41 22) 379 07 44
Web: enviroSPACE - Spatial Predictions and Analyses in Complex Environments - UNIGE
Email: gregory.giuliani@anonymised.com
UNEP/DEWA/GRID-Europe
International Environment House
11, chemin des Anémones, CH - 1219 CHATELAINE
Phone: (+41 22) 917 84 17 Fax: (+41 22) 917 80 29
Web: http://www.grid.unep.ch
Gregory Giuliani
Gregory Giuliani
Web: http://www.unige.ch/envirospace
