[GeoNetwork-users] Extend ISO profiles
Hi everyone,
We are in the process of setting up an infrastructure for geospatial
data, which includes a GeoNetwork server and ISO 19115/19139 metadata.
In our current non-standard metadata catalogue, we have some fields
for internal use that doesn't really map well to any field the ISO
19115 metadata structure. I suppose that we could solve this by
creating a simple extension to the profiles. However, after looking
around for instructions on how to do this, I still don't have a clear
picture of how this should be done in the best way.
Is there someone who could provide me with some guidance or pointers?
A simple example would be that I want to add a free text item
"Internal ID" to the MD_DataIdentification class and that I want this
item to be editable in my templates.
Best regards,
Mattias Lindblad
You would do this in the same manner in which the ISO 19115 extends for
taxonomy. Take a look at pages 129-136 of ISO 19115:2003(E). You would
extend the schema as needed and then document the extensions using the
metadata extension information section. I have attached an example file of
the biological extensions. (BTW, it would be nice if GeoNetwork added the
biological extensions!)
Hope this helps,
Jaci
-----Original Message-----
From: Mattias Lindblad [mailto:geos@anonymised.com]
Sent: Tuesday, February 22, 2011 7:25 AM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Extend ISO profiles
Hi everyone,
Best regards,
Mattias Lindblad
Index, Search & Analyze Logs and other IT data in Real-Time with Splunk
Collect, index and harness all the fast moving IT data generated by your
applications, servers and devices whether physical, virtual or in the cloud.
Deliver compliance at lower cost and gain new business insights.
Free Software Download: http://p.sf.net/sfu/splunk-dev2dev
GeoNetwork-users mailing list
(attachments)
biological.xml (42.6 KB)
Hi Jaci and others,
The GeoNetwork developers are working on support for metadata profiles through a plugin mechanism. This means that you can create and maintain custom metadata profiles and validation in future versions of GeoNetwork.
We will soon have a repository available where users can store and maintain their metadata plugin modules.
Expect this in version 2.8 somewhere around August this year.
Kind regards,
Jeroen
Hope this helps,
Jaci
Hi everyone,
Best regards,
Mattias Lindblad
Free Software Download: Best Open Source Mac Front-Ends 2024
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
<biological.xml>------------------------------------------------------------------------------
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hi, and thanks for your response Jeroen and Jaci!
The future plugin mechanism sounds promising. I look forward to having
a look at that.
I think I understand how I can extend and document a profile. The
biological profile is a good example. Ideally, I would like to have
the extensions more integrated in the GeoNetwork editor and viewer
(neater labels, better grouping, tooltips etc). What would it take to
accomplish that? Am I better off waiting for version 2.8, considering
my quite limited experience with XML/XSD/XSL/...?
Best regards,
Mattias
On Tue, Feb 22, 2011 at 2:59 PM, Jeroen Ticheler
<jeroen.ticheler@anonymised.com> wrote:
Hi Jaci and others,
Kind regards,
Jeroen
Hope this helps,
Jaci
Hi everyone,
Best regards,
Mattias Lindblad
Free Software Download: http://p.sf.net/sfu/splunk-dev2dev_______________________________________________
2011/2/23 Mattias Lindblad <geos@anonymised.com>:
a look at that.
Have a look to Simon's proposal
http://trac.osgeo.org/geonetwork/wiki/pluginprofiles
and the pdf attached for more details. It's available in trunk for
testing if you want.
Cheers.
Francois
Best regards,
Mattias
Hi Jaci and others,
Kind regards,
Jeroen
Hope this helps,
Jaci
Hi everyone,
Best regards,
Mattias Lindblad
Free Software Download: Index, Search & Analyze Logs and other IT data in
Real-Time with Splunk. Collect, index and harness all the fast moving IT data
generated by your applications, servers and devices whether physical, virtual
or in the cloud. Deliver compliance at lower cost and gain new business
insights. http://p.sf.net/sfu/splunk-dev2dev
