Hi and Thanks for GN!
I need some help!
How do I add attributes to the z39.50 attribute list?
How do I add an element set to the z39.50 service?
ATTRIBUTES
It appears that GN currently only allows z39.50 searches on field 4, 62,
1016, 2002
I'm having trouble identifying how to add extra attributes to the Z39.50
service provided by GeoNetwork.
The z3950Client.xsl and z39.50Server.xsl seem like a good start.
There are a range of ~100 attributes that are worth searching on.
How do I add additional attributes?
What do I do then: a) just add the attributes (to the xsls above) and
stick back in JAR; b) add the attributes and recompile; c) (a) or (b)
plus ???
ELEMENTS
The standard "brief" z39.50 response is a) Hit # b) Title
There are a standard set of z39.50 additional element sets
I would like to create a specific element set (Title, FileId, ParentId).
[The addition of FileId and ParentId clearly requires an extension of
the Attribute set]
How do I add an additional Element set?
This is my last major hurdle!
e
Evert Bleys
BRS Data Manager
Biosecurity and Information Sciences
Bureau of Rural Sciences
Department of Agriculture Fisheries and Forestry
GPO Box 855 CANBERRA CITY ACT 260
Ph +61 (0)2 6272 5627
------IMPORTANT - This message has been issued by The Department of Agriculture, Fisheries and Forestry (DAFF). The information transmitted is for the use of the intended recipient only and may contain confidential and/or legally privileged material. It is your responsibility to check any attachments for viruses and defects before opening or sending them on.
Any reproduction, publication, communication, re-transmission, disclosure, dissemination or other use of the information contained in this e-mail by persons or entities other than the intended recipient is prohibited. The taking of any action in reliance upon this information by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error please notify the sender and delete all copies of this transmission together with any attachments. If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one advise the sender by return e-mail accordingly. Only e-mail correspondence which includes this footer, has been authorised by DAFF
