Dag Jeroen,
No, i was using the old external link to my former geonetwork installation
which had the dutch language installed. I did not start to translate the
newest version and used the old link so it was obvious an error would
follow. The english link is now working almost OK.
http://www.thisisnotherealurl.com:8080/geonetwork/srv/en/metadata.show?id=10
4&currTab=simple
A small problem however still exists. When I try to view the WMS service of
the returned metadata javascript gives me an error. I think this is caused
by the fact that the map object is not present when you use the link above
directly in the browser. Only the metadata page is shown. After a push on
the HOME button intermap is loaded and I can view the Map OK. Is it possible
to view the service when using the direct link as shown above? In the former
version of Geonetwork (2.0.2) I used this was working fine.
Wim Blanken
The Netherlands
-----Oorspronkelijk bericht-----
Van: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] Namens Jeroen
Ticheler
Verzonden: Wednesday, June 11, 2008 9:52 AM
Aan: Wim Blanken
CC: geonetwork-users@lists.sourceforge.net
Onderwerp: Re: [GeoNetwork-users] External url link to metadata in
geonetwork
Hi Wim,
Are you saying that such URL will not work when you use a localized
service? That sound strange to me. Could you explain?
Ciao,
Jeroen
On Jun 7, 2008, at 1:02 PM, Wim Blanken wrote:
Hello List,
Sorry list, my problem is solved. I was using the wrong language
with the
new installation. In English it Works now.....
Wim Blanken
[mailto:geonetwork-users-bounces@lists.sourceforge.net] Namens Wim
Blanken
Verzonden: Friday, June 06, 2008 7:11 PM
Aan: geonetwork-users@lists.sourceforge.net
Onderwerp: [GeoNetwork-users] External url link to metadata in
geonetwork
Hello geonetwork users,
I'm really exited about the new ajax look of Geonetwork 2.2. Good
Job Jeroen
and the rest of the community!!!
I've been struggling getting ESRI's Geostickers ISO19115 metadata into
Geonetwork but have succeeded. I had to edit the metadata
extensively before
I was able to get it fully validated. There is certainly a lot of
work to do
untill everyone is fully compliant to 19115/19139.
My (non-WMS) mapserver application has an external link to
geonetwork for
displaying the metadata from a certain layer.
In the former version of geonetwork I was able to show this metadata
by
using the following syntax:
http://www.thisisnotherealurl.com:8080/geonetwork/srv/nl/metadata.show?id=10
4&currTab=simple
Then the metadata record was shown OK using the interface geonetwork
offered.
In version 2.2 the above url shows the metadata accompagnied by a
javascript
error and an empty menu....
Is there a possibility to make a call to geonetwork using an url
with the id
of the metadata-record and let geonetwork display only the data of
this
record without these errors?
Best regards and keep up the good work!!!!!
Wim Blanken
The Netherlands
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
GeoNetwork-users mailing list
No virus found in this incoming message.
Checked by AVG.
Version: 8.0.100 / Virus Database: 270.0.0/1487 - Release Date:
6-6-2008
8:01
Checked by AVG.
Version: 8.0.100 / Virus Database: 270.2.0/1497 - Release Date: 11-6-2008
8:32
