[GeoNetwork-users] External url link to metadata in geonetwork
Dag Jeroen,
Ooooooops answered in Dutch. Sorry for that. Here it is in english..... I am
in a bit of a hurry.......
Thanks Jeroen,
It is however not working. I'm using 2.2 on linus and tried:
http://[mijnip]:8080/geonetwork/srv/en/metadata.show.embedded?id=46&currTab=
simple
I get a white screen with the metadata without menu etcetera... see picture
You got an idea why it is not working?
Wim Blanken
The Netherlands
-----Oorspronkelijk bericht-----
Van: geonetwork-users-bounces@lists.sourceforge.net
[mailto:geonetwork-users-bounces@lists.sourceforge.net] Namens Jeroen
Ticheler
Verzonden: Friday, June 13, 2008 9:09 AM
Aan: Wim Blanken
CC: geonetwork-users@lists.sourceforge.net
Onderwerp: Re: [GeoNetwork-users] External url link to metadata in
geonetwork
Dag Wim,
Try using the following service instead: ../en/metadata.show.embedded?
id=104&currTab=simple
This should open the metadata in the homepage next to the search
window and map viewer.
Ciao,
Jeroen
On Jun 13, 2008, at 8:43 AM, Wim Blanken wrote:
Dag Jeroen,
No, i was using the old external link to my former geonetwork
installation
which had the dutch language installed. I did not start to translate
the
newest version and used the old link so it was obvious an error would
follow. The english link is now working almost OK.
http://www.thisisnotherealurl.com:8080/geonetwork/srv/en/metadata.show?id=10
4&currTab=simple
A small problem however still exists. When I try to view the WMS
service of
the returned metadata javascript gives me an error. I think this is
caused
by the fact that the map object is not present when you use the link
above
directly in the browser. Only the metadata page is shown. After a
push on
the HOME button intermap is loaded and I can view the Map OK. Is it
possible
to view the service when using the direct link as shown above? In
the former
version of Geonetwork (2.0.2) I used this was working fine.
Wim Blanken
The Netherlands
Ticheler
Verzonden: Wednesday, June 11, 2008 9:52 AM
Aan: Wim Blanken
geonetwork
Hi Wim,
Are you saying that such URL will not work when you use a localized
service? That sound strange to me. Could you explain?
Ciao,
Jeroen
On Jun 7, 2008, at 1:02 PM, Wim Blanken wrote:
Hello List,
Sorry list, my problem is solved. I was using the wrong language
with the
new installation. In English it Works now.....
Wim Blanken
[mailto:geonetwork-users-bounces@lists.sourceforge.net] Namens Wim
Blanken
Verzonden: Friday, June 06, 2008 7:11 PM
Aan: geonetwork-users@lists.sourceforge.net
Onderwerp: [GeoNetwork-users] External url link to metadata in
geonetwork
Hello geonetwork users,
I'm really exited about the new ajax look of Geonetwork 2.2. Good
Job Jeroen
and the rest of the community!!!
I've been struggling getting ESRI's Geostickers ISO19115 metadata
into
Geonetwork but have succeeded. I had to edit the metadata
extensively before
I was able to get it fully validated. There is certainly a lot of
work to do
untill everyone is fully compliant to 19115/19139.
My (non-WMS) mapserver application has an external link to
geonetwork for
displaying the metadata from a certain layer.
In the former version of geonetwork I was able to show this metadata
by
using the following syntax:
http://www.thisisnotherealurl.com:8080/geonetwork/srv/nl/metadata.show?id=10
4&currTab=simple
Then the metadata record was shown OK using the interface geonetwork
offered.
In version 2.2 the above url shows the metadata accompagnied by a
javascript
error and an empty menu....
Is there a possibility to make a call to geonetwork using an url
with the id
of the metadata-record and let geonetwork display only the data of
this
record without these errors?
Best regards and keep up the good work!!!!!
Wim Blanken
The Netherlands
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
GeoNetwork-users mailing list
No virus found in this incoming message.
Checked by AVG.
Version: 8.0.100 / Virus Database: 270.0.0/1487 - Release Date:
6-6-2008
8:01
Checked by AVG.
Version: 8.0.100 / Virus Database: 270.2.0/1497 - Release Date:
11-6-2008
8:32
Checked by AVG.
Version: 8.0.100 / Virus Database: 270.3.0/1499 - Release Date: 12-6-2008
7:13
(attachments)
Dag Wim,
yes, in fact I made a slightly complex response that only works when triggered by an AJAX request I realize.
To avoid having this issue come up every time we do an upgrade, I decided to add an option that allows you to use a URL with the UUID of the metadata instead of with the internal identifier. The URL looks like: http://…/geonetwork?UUID=0571bf60-258d-11dd-bfa9-0017f293bd28
It should open the record in the normal browser interface.
Ciao,
Jeroen
On Jun 13, 2008, at 11:06 AM, Wim Blanken wrote:
Dag Jeroen,
Thanks Jeroen,
simple
Wim Blanken
The Netherlands
Ticheler
Aan: Wim Blanken
geonetwork
Dag Wim,
Ciao,
Jeroen
Dag Jeroen,
installation
the
4&currTab=simple
service of
caused
above
push on
possible
the former
Wim Blanken
The Netherlands
Ticheler
Aan: Wim Blanken
geonetwork
Hi Wim,
Ciao,
Jeroen
Hello List,
with the
Wim Blanken
Blanken
geonetwork
Job Jeroen
into
extensively before
work to do
geonetwork for
by
4&currTab=simple
offered.
javascript
with the id
this
Wim Blanken
The Netherlands
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Checked by AVG.
6-6-2008
8:01
Checked by AVG.
11-6-2008
8:32
Checked by AVG.
7:13
<voorbeeld.png>-------------------------------------------------------------------------
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hi Jeroen,
Thx, it Works now!
I was already using the uuid in my link so it was very easy to change the
url.....
Best regards,
Wim Blanken
The Netherlands
Van: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Verzonden: Friday, June 13, 2008 11:16 AM
Aan: Wim Blanken
geonetwork
Dag Wim,
Ciao,
Jeroen
Dag Jeroen,
english..... I am
Thanks Jeroen,
id=46&currTab=
simple
Wim Blanken
The Netherlands
Ticheler
Aan: Wim Blanken
geonetwork
Dag Wim,
Ciao,
Jeroen
Dag Jeroen,
installation
the
4&currTab=simple
service of
caused
above
push on
possible
the former
Wim Blanken
The Netherlands
Ticheler
Aan: Wim Blanken
geonetwork
Hi Wim,
Ciao,
Jeroen
Hello List,
with the
Wim Blanken
Blanken
geonetwork
Job Jeroen
into
extensively before
work to do
geonetwork for
by
4&currTab=simple
offered.
javascript
with the id
this
Wim Blanken
The Netherlands
Checked by AVG.
6-6-2008
8:01
Checked by AVG.
11-6-2008
8:32
Checked by AVG.
12-6-2008
7:13
voorbeeld
.png
Checked by AVG.
Version: 8.0.100 / Virus Database: 270.3.0/1502 - Release Date: 13-6-2008
19:25
