Does the widget gui work for you with IE9? When I tried, only the login bar
would be displayed.
However, it works fine in FireFox.
regards, Chris
View this message in context: http://osgeo-org.1560.n6.nabble.com/ExtJS-widget-GUI-with-IE9-tp4341730p4341730.html
Edit> ok, it seems that the problem is related to an iframe.
I load the widget GUI inside an iframe which seems to cause the problem, but
it works when I load the GUI directly. Do you know how to make it work
within an iframe?
regards, Chris
View this message in context: http://osgeo-org.1560.n6.nabble.com/ExtJS-widget-GUI-with-IE9-tp4341730p4341827.html
