Hello,
I've installed version 3.0.0-0 on Debian 8.0 with Java 8.
http://localhost:8080/geonetwork/srv/eng/home?node=srv :
{"error": { "message": "Service not found" , "class": "ServiceNotFoundEx" , "stack": { "at": "jeeves.server.dispatchers.ServiceManager ServiceManager.java line 422 #dispatch" , "at": "jeeves.server.dispatchers.ServiceManager ServiceManager.java line 384 #dispatch" , "at": "jeeves.server.JeevesEngine JeevesEngine.java line 600 #dispatch" , "at": "org.fao.geonet.services.main.GenericController GenericController.java line 106 #dispatch" , "at": "sun.reflect.NativeMethodAccessorImpl NativeMethodAccessorImpl.java line -2 #invoke0" , "at": "sun.reflect.NativeMethodAccessorImpl NativeMethodAccessorImpl.java line 62 #invoke" , "at": "sun.reflect.DelegatingMethodAccessorImpl DelegatingMethodAccessorImpl.java line 43 #invoke" , "at": "java.lang.reflect.Method Method.java line 483 #invoke" , "at": "org.springframework.web.method.support.InvocableHandlerMethod InvocableHandlerMethod.java line 219 #invoke" , "at": "org.springframework.web.method.support.InvocableHandlerMethod InvocableHandlerMethod.java line 132 #invokeForRequest" , "at": "jeeves.config.springutil.JeevesDispatcherServlet JeevesDispatcherServlet.java line 17 #access$001" , "at": "jeeves.config.springutil.JeevesDispatcherServlet$1 JeevesDispatcherServlet.java line 30 #doInTransaction" , "at": "jeeves.config.springutil.JeevesDispatcherServlet$1 JeevesDispatcherServlet.java line 27 #doInTransaction" , "at": "jeeves.transaction.TransactionManager TransactionManager.java line 63 #runInTransaction" , "at": "jeeves.config.springutil.JeevesDispatcherServlet JeevesDispatcherServlet.java line 24 #doDispatch" , "at": "org.fao.geonet.monitor.webapp.WebappMetricsFilter WebappMetricsFilter.java line 96 #doFilter" , "at": "org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter MetricsRegistryInitializerFilter.java line 31 #doFilter" , "at": "jeeves.config.springutil.PassthroughFilter PassthroughFilter.java line 26 #doFilter" , "at": "jeeves.config.springutil.MultiNodeAuthenticationFilter MultiNodeAuthenticationFilter.java line 98 #doFilter" , "at": "jeeves.config.springutil.JeevesDelegatingFilterProxy JeevesDelegatingFilterProxy.java line 64 #doFilter" } , "request": {} } }
Another issue: startup.sh
rm: cannot remove ‘logs/*request.log*’: No such file or directory
mv: cannot stat ‘logs/geonetwork.log.*’: No such file or directory
mv: cannot stat ‘logs/geoserver.log.*’: No such file or directory
I've created the missing logs subfolder under bin, but it changes nothing.
Any ideas?
With kind regards,
Menashè
