Hi All,
Sorry for cross posting.
I now seem to GN version 2.7 snapshot revision r8695 with ANZMEST
schemaplugins revision r8650.p migrated and running on the new server.
I am now debugging or documenting the errors.
When I start up GN I get the following in the catalina.out file:
06/06/2012 5:33:44 PM
it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem
unless you need to use the GDAL plugins: they won't be
enabled.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
What does the GDAL library do? What are the consequences of not
installing it and how do I install it if I want to use the GDAL
features?
Thanks.
John Hockaday
Hi John,
GDAL is an popular C library for accessing geographic file formats. Geoserver has an optional extension to allow integration with GDAL. You don’t need it in the majority of cases.
Jesse
On Thu, Jun 7, 2012 at 8:03 AM, john.hockaday <john.hockaday@anonymised.com> wrote:
Hi All,
unless you need to use the GDAL plugins: they won’t be
features?
Thanks.
John Hockaday
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
