[GeoNetwork-users] Feature-Catalogue (ISO19110) for GN3 [Marketing Mail] [SEC=UNCLASSIFIED]
Note: ISO 19115-3 supersedes ISO 19139 (ISO 19115-2 is conceptual schematic for "Extensions for acquisition and processing" - focus on imagery)
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences
Department of Agriculture and Water Resources
GPO Box 858 Canberra City ACT Australia 2601
44 Mort St Braddon ACT 2612
Ph: +61 (0)2 6272 5627
Email: Evert.Bleys@...1564...
-----Original Message-----
Sent: Thursday, 27 September 2018 17:51
To: bartolomeo.ventura@...1518...
Cc: Geonetwork-Users@...638...
Subject: Re: [GeoNetwork-users] Feature-Catalogue (ISO19110) for GN3
Hi
You can find additional schemas in https://github.com/metadata101, and
there's a schema for ISO19115-3 (https://github.com/metadata101/iso19115-
3),
that I think it supersedes ISO19115-2, but I'm not an expert in this.
In the repository for https://github.com/metadata101/iso19115-3 (branch
3.4.x) you can find in the README.md instructions to add the plugin. It's not a
straightforward process, as you need to build the code, but should work.
Jose García
On Thu, Sep 27, 2018 at 9:26 AM Ventura Bartolomeo <
bartolomeo.ventura@...1518...> wrote:
> Hi,
> Is there also the support for ISO 19139-2 for the Geonetwork 3.4.1?
> Thanks in advance
> Bart
> From: Jose Garcia <jose.garcia@...444...>
> Sent: Thursday, 27 September 2018 09:09
> To: sulu <andreas.siegel@...955...>
> Hi Andy
> GeoNetwork has support for metadata in ISO19110 metadata schema. You
> can load the templates provided for that schema and create ISO19110
metadata.
> Also if you have metadata for datasets in your catalogue in ISO19139
> format you can related both metadata.
> Probably this documentation can be a good starting point:
> https://geonetwork-opensource.org/manuals/3.4.x/en/user-
guide/describi
> ng-information/index.html
> There's no web service for Feature Catalogue metadata, but you can use
> the search UI and CSW/OAI-PMH protocols to query the metadata.
> Regards,
> Jose García
> On Thu, Sep 27, 2018 at 8:44 AM sulu <andreas.siegel@...955...>
wrote:
> > Hi
> > If i understand correctly GN3 can interpret a Feature-Catalogue to
> > add feature information to a given metadata-set.
> > That would be rather nice in order to flesh out metadata with some
> > technical information about the referred dataset.
> > So i guess such a Feature-Catalogue would be a kind of a web-service.
> > But i cannot find any software, WAR-file, Javascript or what have
> > you that provides such a catalogue.
> > Does any of you guys/gals have implemented such a feature catalogue
> > and/or have knowledge how to set one up?
> > Thanks an a good day
> > Andy
> > Sent from:
> > http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
> > _______________________________________________
> > GeoNetwork-users mailing list
> > GeoNetwork-users@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> > GeoNetwork OpenSource is maintained at
> > http://sourceforge.net/projects/geonetwork
> *Vriendelijke groeten / Kind regards,Jose García
> <http://www.geocat.net/&gt;Veenderweg
> 136721 WD BennekomThe NetherlandsT: +31
> (0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
> <https://twitter.com/geocat_bv&gt;
> <https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
> environment before printing this email.*
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe
NetherlandsT: +31
IMPORTANT - This email and any attachments have been issued by the Australian Government Department of Agriculture and Water Resources. The material transmitted is for the use of the intended recipient only and may contain confidential, legally privileged, copyright or personal information. You should not copy, use or disclose it without authorisation from the Department. It is your responsibility to check any attachments for viruses and defects before opening or forwarding them.
If you are not an intended recipient, please contact the sender of this email at once by return email and then delete both messages. Unintended recipients must not copy, use, disclose, rely on or publish this email or attachments. The Department of Agriculture and Water Resources is not liable for any loss or damage resulting from unauthorised use or dissemination of, or any reliance on, this email or attachments.
If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one, advise the sender by return e-mail accordingly. This notice should not be deleted or altered
Thanks for the explanation.
The question now is: Will Geonetwork adopt or add by default this schema to the basic installation?
Regards
Bart
Sent: Friday, 28 September 2018 04:20
To: Jose Garcia <jose.garcia@...444...>; Ventura Bartolomeo <bartolomeo.ventura@...1518...>
Subject: RE: [GeoNetwork-users] Feature-Catalogue (ISO19110) for GN3 [Marketing Mail] [SEC=UNCLASSIFIED]
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences Department of Agriculture and Water Resources
Hi
3),
(branch
It's not a straightforward process, as you need to build the code, but should work.
Jose García
> Hi,
> Thanks in advance
> Bart
> Hi Andy
metadata.
guide/describi
> use the search UI and CSW/OAI-PMH protocols to query the metadata.
> Regards,
> Jose García
wrote:
> > Hi
> > catalogue and/or have knowledge how to set one up?
> > Andy
> > Sent from:
NetherlandsT: +31
Le ven. 28 sept. 2018 à 07:59, Ventura Bartolomeo <
Before adding it to the default GeoNetwork package, I think we should
update the XSD to the latest version (https://github.com/ISO-TC211/XML)
which includes February 2018 amendment (
https://www.iso.org/standard/73118.html). This would avoid migration steps
in near future. On my side, no funding to cover this for now.
Francois
Regards
Bart
To: Jose Garcia <jose.garcia@anonymised.com>; Ventura Bartolomeo <
Cc: Geonetwork-Users@anonymised.com
imagery)
BLEYS Evert Mr
Data Manager
Email: Evert.Bleys@anonymised.com
> From: Jose Garcia [mailto:jose.garcia@anonymised.com]
> To: bartolomeo.ventura@anonymised.com
> Hi
> 3),
> (branch
should work.
> Regards,
> Jose García
> bartolomeo.ventura@anonymised.com> wrote:
> > Hi,
> > Thanks in advance
> > Bart
> > From: Jose Garcia <jose.garcia@anonymised.com>
> > To: sulu <andreas.siegel@anonymised.com>
> > Hi Andy
> metadata.
> guide/describi
> > Regards,
> > Jose García
> > On Thu, Sep 27, 2018 at 8:44 AM sulu <andreas.siegel@anonymised.com>
> wrote:
> > > Hi
> > > Andy
> > > Sent from:
> NetherlandsT: +31
