[GeoNetwork-users] Feature-Catalogue (ISO19110) for GN3
Hi
If i understand correctly GN3 can interpret a Feature-Catalogue to add
feature information to a given metadata-set.
That would be rather nice in order to flesh out metadata with some technical
information about the referred dataset.
So i guess such a Feature-Catalogue would be a kind of a web-service.
But i cannot find any software, WAR-file, Javascript or what have you that
provides such a catalogue.
Does any of you guys/gals have implemented such a feature catalogue and/or
have knowledge how to set one up?
Thanks an a good day
Andy
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-users-f3860293.html
Hi Andy
GeoNetwork has support for metadata in ISO19110 metadata schema. You can
load the templates provided for that schema and create ISO19110 metadata.
Also if you have metadata for datasets in your catalogue in ISO19139 format
you can related both metadata.
Probably this documentation can be a good starting point:
https://geonetwork-opensource.org/manuals/3.4.x/en/user-guide/describing-information/index.html
There's no web service for Feature Catalogue metadata, but you can use the
search UI and CSW/OAI-PMH protocols to query the metadata.
Jose García
On Thu, Sep 27, 2018 at 8:44 AM sulu <andreas.siegel@anonymised.com> wrote:
Hi
technical
Andy
Sent from:
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Is there also the support for ISO 19139-2 for the Geonetwork 3.4.1?
Thanks in advance
Bart
-----Original Message-----
Sent: Thursday, 27 September 2018 09:09
To: sulu <andreas.siegel@...955...>
Cc: Geonetwork-Users@...638...
Subject: Re: [GeoNetwork-users] Feature-Catalogue (ISO19110) for GN3
Hi Andy
GeoNetwork has support for metadata in ISO19110 metadata schema. You can load the templates provided for that schema and create ISO19110 metadata.
Also if you have metadata for datasets in your catalogue in ISO19139 format you can related both metadata.
There's no web service for Feature Catalogue metadata, but you can use the search UI and CSW/OAI-PMH protocols to query the metadata.
Jose García
On Thu, Sep 27, 2018 at 8:44 AM sulu <andreas.siegel@...955...> wrote:
Hi
technical information about the referred dataset.
that provides such a catalogue.
and/or have knowledge how to set one up?
Andy
Sent from:
*Vriendelijke groeten / Kind regards,Jose García <http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the environment before printing this email.*
Hi
You can find additional schemas in https://github.com/metadata101, and
there's a schema for ISO19115-3 (https://github.com/metadata101/iso19115-3),
that I think it supersedes ISO19115-2, but I'm not an expert in this.
In the repository for https://github.com/metadata101/iso19115-3 (branch
3.4.x) you can find in the README.md instructions to add the plugin. It's
not a straightforward process, as you need to build the code, but should
work.
Jose García
On Thu, Sep 27, 2018 at 9:26 AM Ventura Bartolomeo <
bartolomeo.ventura@anonymised.com> wrote:
Thanks in advance
Bart
To: sulu <andreas.siegel@anonymised.com>
Cc: Geonetwork-Users@anonymised.com
Hi Andy
Jose García
> Hi
> Andy
> Sent from:
Thanks Jose.
Was it just a case or RTFM?
Anyway i'll have a look at the ISO 19110-templates.
So one could create metadata in ISO19139 to describe a dataset in general
and then link the corresponding ISO19110-document to provide a technical
data sheet in order to augment the ISO19139-metadata.
Correct?
And thanks for the swift replies.
Andy
Hi
Sorry Andy, but I think you have misunderstood about the link to the
manual, was nothing related to RTFM. I provided to you the link, in case
you want to get more detailed information about how GeoNetwork works with
metadata, apart of the feedback I provided.
About the links between metadata, it's correct your understanding, the
metadata editor in GeoNetwork has options to link metadata with other
metadata. You can find additional details about relating metadata in
https://geonetwork-opensource.org/manuals/3.4.x/en/user-guide/associating-resources/index.html
Jose García
On Thu, Sep 27, 2018 at 11:28 AM sulu <andreas.siegel@anonymised.com> wrote:
Thanks Jose.
Correct?
Andy
Sent from:
Thanks Jose!
Jou replies are great!.
I'll definitly will try out this combination.
Andy
Thanks a lot Jose Garcia,
I will have a look on that instructions
Bartolomeo
Sent: Thursday, 27 September 2018 09:51
To: Ventura Bartolomeo <bartolomeo.ventura@...1518...>
Cc: sulu <andreas.siegel@...955...>; Geonetwork-Users@...638...
Hi
You can find additional schemas in https://github.com/metadata101, and there's a schema for ISO19115-3 (https://github.com/metadata101/iso19115-3), that I think it supersedes ISO19115-2, but I'm not an expert in this.
In the repository for https://github.com/metadata101/iso19115-3 (branch 3.4.x) you can find in the README.md instructions to add the plugin. It's not a straightforward process, as you need to build the code, but should work.
Jose García
On Thu, Sep 27, 2018 at 9:26 AM Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> wrote:
Thanks in advance
Bart
From: Jose Garcia <jose.garcia@...444...<mailto:jose.garcia@…444…>>
To: sulu <andreas.siegel@...955...<mailto:andreas.siegel@…955…>>
Cc: Geonetwork-Users@...638...<mailto:Geonetwork-Users@…638…>
Hi Andy
Jose García
On Thu, Sep 27, 2018 at 8:44 AM sulu <andreas.siegel@...955...<mailto:andreas.siegel@…955…>> wrote:
Hi
Andy
Sent from:
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
Jose García
[Image removed by sender.]<http://www.geocat.net/&gt;
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664<tel:+31318416664>
[Image removed by sender.]<https://www.facebook.com/geocatbv&gt; [Image removed by sender.] <https://twitter.com/geocat_bv&gt; [Image removed by sender.] <https://plus.google.com/u/1/+GeocatNetbv/posts&gt;
(attachments)
